95 ZJ won't start, crank, or turnover. Battery, starter good. New starter relay - JeepForum.com
post #1 of 6 Old 03-26-2018, 05:21 PM Thread Starter
hansoulow
Greetings,
Jeep was dead on Friday, so I charged the battery. Still wouldn't start so I took it to O'Reilly's to check it, they said it was good. Next step was to get the starter checked, took it to O'Reilly's and they said it was good and the solenoid was good as well. I got a second opinion on it at Autozone and they said the same thing: starter and solenoid good. After putting the starter back on, I put in a new starter relay. Interestingly, the Jeep started after that. I thought the problem was solved. Unfortunately, on my way out the door this morning to work, the Jeep wouldn't again start. Not sure what's next, and I'm hoping you guys can help out. Conveniently, it's also cold and raining almost all week.
What I've done so far:
  • Checked battery (It's an "18 month" battery in it's ~16th month, but O'Reilly's said it was good)
  • Cleaned terminals
  • Checked starter and solenoid
  • Replaced starter relay
  • Tried starting in neutral and wiggling the shifter
  • My reverse lights do come on (I've read that that's how you check the neutral safety switch, though I'm not sure)
Other useful information:
  • When I try to start, headlights stay full brightness and don't dim
  • Starter clicks when I try to start
  • No codes being thrown
hansoulow is offline
post #2 of 6 Old 03-28-2018, 08:07 AM
GOLDWING
GOLDWING's Avatar
Welcome to the forum!
Clean your engine bay ground points. (disconnect, clean the terminal and anchor point, reassemble)
GW
P.S. I will post a link in a minute with pics of the grounds.
"The Dude Abides"
GOLDWING is offline
post #3 of 6 Old 03-28-2018, 08:17 AM
GOLDWING
GOLDWING's Avatar
Check out post #23.
https://www.jeepforum.com/forum/f13/v...-drop-4221098/
GW
"The Dude Abides"
GOLDWING is offline
post #4 of 6 Old 03-28-2018, 10:24 AM
kg6mov
Hears the voices
kg6mov's Avatar
If the starter solenoid is clicking then the NSS, starter relay, pcm, etc are acting correctly.
Basically, is the solenoid tries to give the motor power and the motor doesn’t spin, you’re most likely having one of three issues:
1. Battery is ****ed (not likely given the headlights don’t dim)
2. Starter motor is ****ed
3. You’ve got a bad ground/connection
kg6mov is offline
post #5 of 6 Old 03-30-2018, 06:08 PM
RedRiverT
The starter may not really be good, even though it tested OK at the parts stores. It may not develop enough torque to turn the engine. They probably just hooked power to it to see if it would spin freely.
My suspicion is battery cables, one or both, as kg mentions in his #3. If not the terminals/connections, they can corrode down inside the insulation and then the resistance gets too high for enough current to pass.
RedRiverT is offline
post #6 of 6 Old 04-06-2018, 05:38 PM
MaintMech
Old and in the way
MaintMech's Avatar
One other option is that the key switch is bad.
At first the Jeep wouldn't crank about once a month. I'd bang on the stater and it'd crank and fire. When it wouldn't fire 3 times in one day, it went to see my shop.
Turns out the ignition switch was bad. Now I have to carry two keys, one for the doors and one to start the bugger.
Yeah, I could have fixed it myself but I'm old, broke down and tired.
35 days till retirement and poverty. Then I'll have time and no money to keep this heap on the road.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
