95 zj v8 - JeepForum.com
post #1 of 3 Old 09-25-2021, 08:55 AM Thread Starter
Harrysaxx
95 zj v8
I am replacing the cps and I’m waiting on the Mopar sensor but I had it stall out last week but all the lights and everything stayed on. It kept cranking but won’t turn over. Starter, caps, rotor, spark plugs as well as new terminals and battery. I have fuel in the rail and can hear the fuel pump so I’m not sure if this is the issue but I had very low idle rough as well.
Also the guy I bought it from half A** the wiring because I thought my fuses were blown but after testing each fuse and the pins? Most of half my fuses on the side of the dash don’t work and two under the hood don’t work. Would that be wiring that he cut and didn’t repair?
Harrysaxx is offline
post #2 of 3 Old 09-25-2021, 09:26 AM
HighLonesome
HighLonesome's Avatar
Not sure what you mean by fuses don't work. You mean there is no voltage to some of them? That would mean they are enabled by the ignition.
Without seeing what you got, my advice is to restore the stock wiring and make sure all the grounds are solid as a rock...engine to chassis, chassis to battery, engine harness.
HighLonesome is offline
post #3 of 3 Old 09-25-2021, 10:02 AM Thread Starter
Harrysaxx
All fuses that don’t work for interior are these.
The ones in the pdc don’t work are trans/ecu and A/C.
16,20,24,15,10,18,22,17,21
Yes I have no voltage when testing sockets and test light doesn’t light up when testing fuses even tho they are not blown.
