95 grand cherpkee transmission - JeepForum.com
post #1 of 8 Old 04-15-2019, 06:02 PM Thread Starter
coltonk
I have been having some trouble with the jeep. After talking to the transmission shop that recent rebuilt my transmissions they say it might be the electronic shift module. Does anyone know where this module is located? Is it in the transmissions or mounted elsewhere?
coltonk is offline
post #2 of 8 Old 04-16-2019, 06:50 AM
LordHobbit
LordHobbit's Avatar
What engine/transmission do you have.
Help us help you!
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #3 of 8 Old 04-16-2019, 09:43 AM
Timo_90xj
Timo_90xj's Avatar
Yeap, what engine and what transmission? What are the symptoms you've been getting?
***Under construction***
Timo_90xj is offline
post #4 of 8 Old 04-17-2019, 07:54 PM Thread Starter
coltonk
I believe it is the 22re
coltonk is offline
post #5 of 8 Old 04-17-2019, 07:56 PM Thread Starter
coltonk
The transmissions shift one time from a dead stop then doesnt shift anymore. The engine is thee 6 cyl and the transmission is the 22RE
coltonk is offline
post #6 of 8 Old 04-17-2019, 10:12 PM
kg6mov
Hears the voices
kg6mov's Avatar
42re . . .
A 22re would be a two speed transmission . . .
The TCM is in the drivers footwell on a 95.
kg6mov is offline
post #7 of 8 Old 04-20-2019, 05:13 PM Thread Starter
coltonk
Where is the obd test port for the 95's
coltonk is offline
post #8 of 8 Old 04-20-2019, 05:18 PM Thread Starter
coltonk
Originally Posted by kg6mov View Post
42re . . .
You are correct. ..the transmission has a first, second, drive and overdrive
coltonk is offline
Auto to Manual Transmission Swap TheFreedombird TJ Wrangler Technical Forum 43 01-09-2020 11:10 AM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
2018 Grand Cherokee WK2 Transmission Problems Jeebs WK2 Grand Cherokee Forum 27 09-18-2019 07:35 PM
Need help on 05 5.7 trans range sensor powerstroke01 WK Grand Cherokee & XK Commander Forum 1 03-07-2019 12:12 PM
Do I have another faulty PCM? rcroane TJ Wrangler Technical Forum 42 02-13-2019 12:08 PM
