94 Grand Cherokee 4.0 I6 - JeepForum.com
post #1 of 4 Old 07-22-2021, 04:19 PM Thread Starter
seankuli
Bought this Jeep a few weeks ago. Been sitting in a garage for a while. Replaced the fuel pump, the ECM, the rad, the A/C condenser, brakes, tires and thought it was good. It fires up cold everytime, no issues. Once the engine is warm, it will shut down while turning or at a stop light and then won't start back up again. Just cranks and cranks. Once it sits for half hour, fires right back up. and so on and so on.
149,000km. Not sure what the issue is. When I do the key flip, I get a Code 12, 11, 62 and 55. Could it be the crankshaft sensor. Camshaft sensor was replaced a few years ago.
TIA
seankuli is offline
post #2 of 4 Old 07-23-2021, 02:54 AM
jtec
jtec's Avatar
2014 JK Wrangler
code 11 is for no CKP (crank sensor) signal. So might want to check that out, if history is unknown I would replaace that to start.
That code 62 has me thinking - as its a PCM mileage issue - WHY did you change PCM, do you have old unit, can you contact remanufacturer of PCM to ask for advice?
jtec is offline
post #3 of 4 Old 07-23-2021, 08:57 AM Thread Starter
seankuli
Mechanic replaced the PCM telling me one of the connections was bad. So when I researched it, it was saying code 62, PCM failure SPI mileage not stored. I think I'll try and change the CPS first and see if that does the trick. Other than that, runs great.
seankuli is offline
post #4 of 4 Old 07-23-2021, 11:36 AM
jtec
jtec's Avatar
2014 JK Wrangler
FYI CKP and CPS are the same. we always suggest OEM component for this.
jtec is offline
