94 Blower Motor resistor - JeepForum.com
 2Likes
  • 1 Post By MaintMech
  • 1 Post By Timo_90xj
post #1 of 4 Old 07-15-2020, 09:27 AM Thread Starter
OverlandZJ
1994 ZJ
Stopped for fuel awhile back and started Jeep, blower motor decided to only work on high. Common issue i see..
My rig is a 94 with auto climate control. Looking at Rockauto there seems to be two..both auto temp but one specifying a particular stamping number.
Is there in fact two or is this something the particular manufacturer wants to confuse me with? Hate to order at ~$120 and get the wrong part.
Appreciate..
OverlandZJ is offline
post #2 of 4 Old 07-15-2020, 10:07 AM
MaintMech
Old and in the way
MaintMech's Avatar
What I've done in the past is gone to something like this: https://www.mymoparparts.com/oem-par...2119524?c=az0x Look up the OEM part # and then gone to Rock Auto. RA is pretty cheap but I find I have trouble with looking up their parts.
OverlandZJ likes this.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 4 Old 07-15-2020, 11:12 AM
Timo_90xj
Timo_90xj's Avatar
I see no indication on Rockauto that the '94 ATC controller has two different options. I see two manufacturers that both provide the same part number.
Manual A/C resistor is the same for '93-'98, ATC controller part number changes '93-'96 / '97-'98. I actually do not know why ATC controller would be the same up to '96, even though facelift was done for '96 model year. I guess it could be a mistake, or it's one of the 1996 year model Jeep things.
***Under construction***
Timo_90xj is offline
post #4 of 4 Old 07-16-2020, 07:00 AM Thread Starter
OverlandZJ
1994 ZJ
Timo.. top one indicates a particular stamping number, while showing the same part number. ? I dunno man.. i'll just order and see what happens.
WVE 4P1721 {#4720046, JA1843} Info
With automatic temperature control (you can set a specific numeric temperature), with Stamping # 16173860
Part image
$114.79
1
Add to Cart
STANDARD MOTOR PRODUCTS RU759 {#4720046} Info
w/ Automatic Temperature Control (you can set a specific numeric temperature)
Part image
$132.79
