94 4.0 turns over but no fire - JeepForum.com
post #1 of 16 Old 01-06-2016, 01:05 PM Thread Starter
Mike Romain
Folks, I have a 94, 4.0 auto that will spin over, but won't fire up. It started intermittent, got 3 more starts after the first failure. No fuel pump prime noise and no tach flicker, but pump is only one year old, banged on tank just in case.. Tried swapping relays around, no difference. At first when I checked the codes, it just kept repeating 5 over and over. Tried it several times. Left it sit for a month, battery was dead, put a fresh charged one in and still the same, spins but no fire and no fuel pump prime noise and no tach flicker. Except, it now gives code 12 and 55 like it should.
Any ideas where I should check next?
Mike
Mike Romain is offline
post #2 of 16 Old 01-06-2016, 02:13 PM
gzj
1994 ZJ
I have the same issue. It's intermittent. It's will just sit there and spin and spin and make a raw gas smell out the tail pipe. Whenever that happens, I keep my foot on the gas, crank the key, and have a person spray hotrod gel aka starting fluid into the throttle body. It will start after like 20 seconds of cranking. After that, I keep it up at like 2500 rpm and put my hand over the intake. Engine dies out, and sucks all the garbage through the venturies. Then it's fine for like another month or so.
gzj is offline
post #3 of 16 Old 01-06-2016, 05:13 PM
kobe3006
Ok, it could be several issues, but best thing to do is Trouble shoot your problem..
1. (Crankshaft position sensor) on top of the transmission behind the engine.
2. Bad Ground somewhere on engine,
3. . Bad Fuel Pump, unplug your fuel line on top of your engine the one going into the fuel injector line... turn the key and see if your getting gas to the front of the engine. Does gas shoot out of it?
4. Bad Connection on crankshaft position sensor to the connector going toward the coil... Unplug it plug it in see if it start...
kobe3006 is offline
post #4 of 16 Old 01-06-2016, 07:32 PM
kobe3006
My bet is crankshaft position sensor
kobe3006 is offline
post #5 of 16 Old 01-06-2016, 10:35 PM
Uniblurb
Uniblurb's Avatar
Make sure your negative battery cable is in real good shape along with your new used battery. The PCM grounds on the negative battery terminal on the 93-95 unlike on the engine block on the 96-98 4.0's. A bad PCM ground, battery, or neg cable may have been why you were getting repeat "5's" on the key trick test even though it may be working correctly now.
There's lots of real good troubleshooting info in the dirty dozen thread in my signature.
Here's a thread which is specific to the 94 4.0 fuel pump not priming along with no spark although different than yours in the CEL is on all the time.
https://www.jeepforum.com/forum/f13/9.../#post26120930
The OP never did come back to post if he solved his problem. If nothing else some good tests and wiring diagrams in the above thread.
A lot of info but there can be many different causes for your problems. Good luck.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #6 of 16 Old 01-07-2016, 10:33 AM Thread Starter
Mike Romain
Thanks for the info and links, my first suspect is the ground circuit for sure. I live in the rust belt big time. Will do some poking around with my meter in the next few days and will post back.
Mike
post #7 of 16 Old 01-17-2016, 07:41 AM
TIPPEDITOVER
No signal
TIPPEDITOVER's Avatar
1978 CJ5
You mentioned swapping relays around, just caught that. I was gonna suggest swap ASD for A/C relay, but that's done.
If you happen to see an issue present on the pump ground and want access to clean it, the pump ground is conveniently located under the driver seat. I just cleaned mine for preventative measures, because I had my carpet out for cleaning. The ground is one of those type that the screw down right on top of the paint/primer and it has sharp edges that dig into the metal in four places.
If it's not a ground issue somewhere then yeah, CPS or ECU
Would like to know what you find out once you fixed it.
Ongoing CJ-5 to CJ-6 Build:
TIPPEDITOVER is offline
post #8 of 16 Old 01-17-2016, 08:25 AM
TIPPEDITOVER
No signal
1978 CJ5
Edit: disregard this post. The OP in the following linked thread stated his engine would start and then immediately die. That's not your symptoms.
Does yours have a security system? If so, here's something else to consider. https://www.jeepforum.com/forum/newre...ply&p=33623586 Similar symptoms to yours in that the battery died.
Originally Posted by LucySUP View Post
Hi,
the Battery and connectors where replaced when the CPS was put in.
I got it to run. Not sure how but I believe it was security.
I did the Battery disconnect and back on, keys in every doors, but in another PCM and then the old one again, grounded the Purple Yellow Wire and took out and cleaned out and put back in all the fuses.
Since there was no flashing lights or horn or idiot lights, it is was hard to tell when exactly the security came off.
I also got the gauges and power windows to work. I read somewhere that a bad passenger driver seat can short out that circuit. I cleaned and replaced the J fuse and just slightly adjusted the passenger seat and bang, gages and windows were back on.
post #9 of 16 Old 01-26-2016, 01:14 PM Thread Starter
Mike Romain
Follow-up and question. Finally got time to get after it and the power plug at the pump seemed to have issues. I wiggled it and got one start, then unplugged it a couple times and have gotten multiple starts. Going to fill it with dielectric grease tomorrow.
Now for the question, will an alternator from a 2000 Cherokee 4.0 fit on it? It is a 94 4.0.
Ya it runs, but the alternator is seized rock solid. Even rounded off the nut using a six point socket trying to turn it. Jeeps.... Not one thing, its another... Already emptied every pocket, got 4 of em, Jeeps that is and the only thing running is my skidoo on our 1 km long driveway. Lol.
Mike
post #10 of 16 Old 01-26-2016, 08:35 PM
belalerede
If the alternator siezed just from sitting around you can free it up by pouring pb blaster into it and then after it has set for a while use an impact wrench on a lower setting and keep switching it back and forth oon the pully nut. Ive done it with good results sometimes.
As far as if a 2000 model alternator will fit I am not sure. If they use the same housing it should bolt right on. You may have to change the electrical plugs to get it to work.I have adapted them before but its been a while.
belalerede is offline
post #11 of 16 Old 01-26-2016, 08:54 PM
kg6mov
Hears the voices
kg6mov's Avatar
The WJ alts have different connectors. Chrysler changed to a two pin plug in 99.
kg6mov is offline
post #12 of 16 Old 01-27-2016, 03:04 AM Thread Starter
Mike Romain
Can they be adapted? I am pretty good with wiring.
Mike
post #13 of 16 Old 01-27-2016, 03:07 AM Thread Starter
Mike Romain
Thanks, it was doing the occasional scream and smoke before it died and sat so I figure it was giving up then. Could even be the original. I have it soaking, we will see.
Mike
post #14 of 16 Old 01-28-2016, 03:34 PM Thread Starter
Mike Romain
So went brand new for the alternator. $205.00 Canadian with a lifetime warranty. Hard to beat that.
Thanks all.
Mike
post #15 of 16 Old 01-31-2016, 07:32 PM
belalerede
Thanks all.
if your gonna keep it. might as well not have to ever buy another
