94 4.0 Not Getting Fire - JeepForum.com
post #1 of 6 Old 06-10-2019, 10:05 AM Thread Starter
Henry347
Henry347's Avatar
1994 ZJ
My ZJ just up and died the other day in the driveway, checked to see if it's getting fuel and it is. Then checked to see if it's getting spark but it's not. I put a new cap and rotor on it a few months back. So I figured it was the crankshaft sensor because I've had them do that before. And put a new one on it but still not getting spark.
I took off a plug wire and hooked it straight to the coil, put a plug in it, put it on some metal and it not getting juice while I'm cranking it over. Seems to me like the coil is bad but figured I'd see if anybody had some opinions before I buy another coil.
Henry347 is offline
post #2 of 6 Old 06-10-2019, 11:42 AM
jtec
2014 JK Wrangler
BASIC'S
with KOEO (Key On Eng OFF) -
Is there 12v at injectors?
Is there 12v at coil?
YOU DID TRY TO GET CODES, AND CHECKED ALL FUSES?
jtec is offline
post #3 of 6 Old 06-10-2019, 01:04 PM Thread Starter
Henry347
Henry347's Avatar
1994 ZJ
Yea all the fuses checked out good, but don't got anything I can check and see if it's getting 12v at the coil with the key on. And there's no codes on in the jeep.
Henry347 is offline
post #4 of 6 Old 06-11-2019, 10:14 AM
1stZJTRUCK
1stZJTRUCK's Avatar
Check the connection on the coil. I’ve seen them come loose and not let it get power.
1stZJTRUCK is offline
post #5 of 6 Old 06-11-2019, 12:01 PM
jtec
2014 JK Wrangler
tool is @10$ - sears? most auto part stores
jtec is offline
post #6 of 6 Old 06-11-2019, 02:29 PM
LordHobbit
LordHobbit's Avatar
my '93 use to eat coils for lunch. and breakfast. and dinner. and snack. and ... you get the picture.
Test for the 12V at the coil. The coil is a fairly inexpensive part and can be replaced in about 5 minutes. Get a coil with a lifetime warranty.
93 red ZJ 194k 4.0. Spent more money than I should have ...
LordHobbit is offline
