93 ZJ engine swap question - JeepForum.com
post #1 of 3 Old 03-22-2019, 07:07 PM Thread Starter
daringescape
OK, Ive never done an engine rebuild or swap before and Im a little worried about tackling this.
I have a 93 zj with an AW4 transmission. I haven't taken the engine apart yet, but I think I have a broken rod. It could be just the rod bearings, but It is REALLY loud when started.
My question is this. I have the chance to pick up an engine from a 94 Cherokee for $400 - will it fit my zj? and should I do that and just swap it out, or should I try and replace the broken rod instead?
Its also possible that my zj engine is toast and I would either need to rebuild or replace anyway.
daringescape is offline
post #2 of 3 Old 03-23-2019, 08:45 AM
Black93ZJ
It will work. Just use your engine accessory drive brackets and pulleys. Also use your flexplate as it will match your torque converter. I put a 96 ZJ engine in my 93 and used the flexplate from my original engine as there was a 90 degree and offset style bolt pattern for the TC. Swap all your sensors and needed items and you should be GTG.
Black93ZJ is offline
post #3 of 3 Old 03-23-2019, 08:56 AM
Timo_90xj
Timo_90xj's Avatar
OP has an AW4, so it's the same transmission & flexplate to what XJs used.
***Under construction***
Timo_90xj is offline
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
The 5.2/5.9 swap guide for YJs SunDevilJeeper YJ Wrangler Technical Forum 153 12-29-2018 10:50 PM
CRD engine stalled + ECT + CEL plunix WK Grand Cherokee & XK Commander Forum 8 10-02-2018 05:40 PM
Engine Swap Question jabawoki WJ Grand Cherokee Forum 2 09-14-2018 10:48 AM
231 to 241 swap question blazenorange Engines & Drivetrain 4 05-29-2018 10:34 PM
