5.9 fan relays - JeepForum.com
post #1 of 9 Old 08-23-2018, 01:06 PM Thread Starter
UTNiner
5.9 fan relays
My low speed fan relay wasn't always clicking on so I swapped it with the high speed for now but I'm looking to replace one and maybe have a spare. After doing multiple searches and only coming up with one napa PN with a cost of $80, I'm hoping someone has another PN or solution that's not so expensive for a damn relay.
Platinum 5.9, 3.5" lift, 231 w/SYE 265/75/16 on Stock Wheels
UTNiner is offline
post #2 of 9 Old 08-23-2018, 02:14 PM
RWC
Alternatives are listed here on post #9:
https://www.jeepforum.com/forum/f13/...hread-1717434/
I'm running both of the NAPA relays since that was what was in stock locally to me. A buddy of mine is running the BWD relay that he found cheaper locally to him.
RWC is offline
post #3 of 9 Old 08-23-2018, 02:47 PM Thread Starter
UTNiner
I actually used this thread to find the napa PN but I must have looked over the others. Guess when I finally decide or get pushed to get new ones I'll just have to eat that cost and chock it up to having a niner. Thanks for the info
UTNiner is offline
post #4 of 9 Old 08-23-2018, 02:48 PM
kg6mov
Hears the voices
kg6mov's Avatar
You could convert to the volvo relay, but the napa part is the easy path.
kg6mov is online now
post #5 of 9 Old 08-23-2018, 03:33 PM
Timo_90xj
Timo_90xj's Avatar
I'm still amazed about the price of those high- amp relays there across the ocean.
The first two I bought here for about 5-7€ were crap, but the next two I bought have been working flawlessly. They cost around 10€ (roughly 12$) each...
70 amp rating, copper contacts.
***Under construction***
Timo_90xj is offline
post #6 of 9 Old 08-24-2018, 10:13 AM Thread Starter
UTNiner
Do the Dakota and Durango's have the same relays?
UTNiner is offline
post #7 of 9 Old 08-24-2018, 10:56 AM
HighLonesome
HighLonesome's Avatar
Looks like this relay
http://www.galco.com/buy/NTE-Electro...caAmXXEALw_wcB
But this one doesn't have the bottom protective shroud. I've never seen an NTE relay fail., they are the best IMO.
HighLonesome is offline
post #8 of 9 Old 08-24-2018, 11:06 AM Thread Starter
UTNiner
What is the amps on the stock? 40?
UTNiner is offline
post #9 of 9 Old 08-24-2018, 11:21 AM
HighLonesome
Probably 70. You can tell by looking at the spades. 70 amp relays have 3/8" spades in the power circuit. 40 amp relays have 1/4" spades all around.
