5.2 engine cooling - Page 5 - JeepForum.com
 34Likes
post #61 of 72 Old 06-06-2021, 04:15 AM
PolkaPower
PolkaPower's Avatar
Originally Posted by HassZJ1998 View Post
yes it is the original, btw i marked one of the fan with white spray so i can see how fast it's going, yea it looks slow.
question, is it possible that the fan runs only on one speed ? or it is the relay that needs to be checked ? you know these 2 black relays under the edge of the right (passenger) side fender !! and if so how to check the relays ?
appreciate your help
It's possible that one speed only works. Relay or temp sender could be not working. I don't use the factory fan wiring so someone else will have to elaborate.
Sent from my iPhone using Tapatalk
HassZJ1998 likes this.
PolkaPower is offline
post #62 of 72 Old 06-06-2021, 04:34 AM Thread Starter
HassZJ1998
HassZJ1998's Avatar
it's ok buddy, i appreciate it.
please take a look at my posts maybe you can help me, i always appreciate any feedback, thank you.
HassZJ1998 is offline
post #63 of 72 Old 06-06-2021, 12:14 PM
hilljacknm
You'll want to move those down as far as you can. I have the same set up and it blocked enough airflow to cause higher temperatures. I moved them down and cut out some sheet metal to create more surface area for the radiator and it helped quite a bit.
Sent from my iPhone using TapatalkAttachment 3991123
Cut a little out of my bumper also.....
It helps when driving. Figured I could always cut more out. Thanks for posting yours.
1996 ZJ 5.2
Doug Thorley Headers, Kolak exhaust
B&M 70268 trans cooler
BFG KM3 30x9.50
hilljacknm is offline
post #64 of 72 Old 06-06-2021, 04:55 PM
PolkaPower
PolkaPower's Avatar
I'm eventually going to cut it all out and weld in something smaller and stronger but it'll be awhile. For now it cools well in summer with the bumper on.img_20190527_120118.jpg
post #65 of 72 Old 06-07-2021, 06:53 PM
sldoaktree
sldoaktree's Avatar
Well this is what were lookin like now
PolkaPower and HassZJ1998 like this.
sldoaktree is offline
post #66 of 72 Old 06-07-2021, 09:32 PM
sldoaktree
sldoaktree's Avatar
Polka what front bumper is that btw? Who makes it?
post #67 of 72 Old 06-07-2021, 09:59 PM
PolkaPower
PolkaPower's Avatar
5.2 engine cooling
Home made. I copied this XJ bumper I liked. I still need to add the fairlead.img_20190918_175056-copy.jpg
post #68 of 72 Old 06-08-2021, 12:12 AM Thread Starter
HassZJ1998
HassZJ1998's Avatar
Home made. I copied this XJ bumper I liked. I still need to add the fairlead.Attachment 3991477
Attachment 3991479
looks great, job well done.
PolkaPower likes this.
post #69 of 72 Old 06-08-2021, 12:15 AM Thread Starter
HassZJ1998
HassZJ1998's Avatar
wishing you the best buddy, massive job, thanks for sharing the photos
post #70 of 72 Old 06-08-2021, 06:15 AM
sldoaktree
sldoaktree's Avatar
Thanks! Hope you get what you need and ill keep you updated on temps after i test run it..
Front bumper looks great wish you had a spare lol
post #71 of 72 Old 06-10-2021, 09:57 AM
sldoaktree
sldoaktree's Avatar
So driving in 90+ weather up a decent grade a/c full blast i stayed at 205 temp with windows down no a/c i was runnin 190… thanks for the help and pics… glad i didnt do a head gasket like someone was so sure of..
post #72 of 72 Old 06-11-2021, 02:16 AM Thread Starter
HassZJ1998
HassZJ1998's Avatar
thanks again Polka, narrowing the places to start looking always helps.
I really appreciate it.
