5.2 engine cooling - Page 2 - JeepForum.com
 34Likes
post #16 of 72 Old 05-31-2021, 09:32 AM
kg6mov
Hears the voices
kg6mov's Avatar
Note that the waggy didn't come with an overdrive trans. The OD is a big part of why we have overheating issues on these transmissions.
Also note that for a factory 5.2 the computer will up the idle speed if the temp climbs too high. Mopar knew that the mech fan (and water pump) aren't doing enough at idle to really cool things. Not sure if a 5.9 PCM will do that.
HassZJ1998 likes this.
kg6mov is offline
post #17 of 72 Old 05-31-2021, 09:45 AM
AdidasCJ
AdidasCJ's Avatar
Living in the Southern California Desert; I am running the 5.9 efan on my 5.2 with the temp sensors in the top and bottom hose as well. In the dead of Summer with the AC on I see a temp of ~212-215. I also have vent cut into my hood to help ambient heat escape. Make sure your water pump is working, check to ensure the fan shroud is proper and not hanging off and what not. With the fan on, you should be able to have a peice of paper suck to your grill without having to hold it. Ensure your coolant is clean and not full of crap.
Bypassing the trans loop will help bring the temp down a couple degrees, I have mine bypassed that loops through the radiator.
A updated/upgraded aluminum radiator may help. I am running the one from Radiatorexpress their dual row.
Ensure no air is in your cooling system.
Going back to clutch fan in your situation wont be better if you sit in traffic. Efan will work better in traffic.
96 ZJ 5.2; IRO 4.5, Bilstein 5100s, 265/75/16, IRO OTK, 5.9 efan, 242.
00 TJ 4.0; MOSTLY stock.
AdidasCJ is offline
post #18 of 72 Old 05-31-2021, 09:54 AM
kg6mov
Hears the voices
kg6mov's Avatar
The radiator express rad is probably hurting you there. With the 5.9 efan you should be able to keep things under 200 if you're not loading up the engine.
kg6mov is offline
post #19 of 72 Old 05-31-2021, 10:52 AM
StPaul59
Originally Posted by PolkaPower View Post
It automatically ramps up fan speed as needed. There is an on off switch for water and it ramps to full speed when the ac is on. You can set it to different temperature as well.
The liberty fan blade is bolt on and seems to move more air than the stock ZJ fan. I have one but never installed it because I was still tinkering with various electric Gan set ups.
Sent from my iPhone using Tapatalk
Your setup sounds ideal, the way the factory should have done it. You almost have to have it on high anytime the ac is on anyway. I'm just wondering how you would hook this into a 2-speed fan based on their instructions. It just says hook into positive on the fan motor. I would have to assume that you would hook into high speed and leave the low-speed empty on the fan motor itself?
StPaul59 is offline
post #20 of 72 Old 05-31-2021, 01:48 PM
wingless
wingless's Avatar
1994 ZJ
The Derale 14210 Cooling Pan added during my 46RH Transmission Rebuild helps augment the overall vehicle cooling.
wingless is offline
post #21 of 72 Old 05-31-2021, 04:43 PM
PolkaPower
PolkaPower's Avatar
Yes
PolkaPower is offline
post #22 of 72 Old 05-31-2021, 05:31 PM
StPaul59
Yes
Is the 75 model overkill or did you get the 45?
StPaul59 is offline
post #23 of 72 Old 05-31-2021, 05:34 PM
PolkaPower
PolkaPower's Avatar
5.2 engine cooling
I'm using the 45 but I was over budget fiddling with several different e fans so cost decided that.
post #24 of 72 Old 05-31-2021, 06:06 PM
StPaul59
Would it be better in any way to have the 75a or is the 45 just fine?
StPaul59 is offline
post #25 of 72 Old 05-31-2021, 06:17 PM
PolkaPower
PolkaPower's Avatar
I've read people using the 35 and have no problem so the 45 is probably more than adequate for our needs. I've never had any issues with it and it's worked flawlessly since I installed it.
post #26 of 72 Old 05-31-2021, 06:22 PM
PolkaPower
PolkaPower's Avatar
Here's an old ZJ related thread about the 35.
http://mallcrawlin.com/forum/archive...hp/t-7729.html
post #27 of 72 Old 05-31-2021, 07:44 PM
StPaul59
Great info, I think this is way I need to go.
StPaul59 is offline
post #28 of 72 Old 05-31-2021, 08:31 PM
PolkaPower
PolkaPower's Avatar
You're welcome. I was a bit apprehensive to use the temperature probe in the fins and asked what screw in probe for a hose to use and he replied that the fin probe was quite good and that wasn't necessary. It's never been an issue. I put a dab of rtv behind it just incase.
Fyi
post #29 of 72 Old 06-01-2021, 01:06 AM Thread Starter
HassZJ1998
HassZJ1998's Avatar
thank you Adidas CJ
my ZJ has these 2 cuts covered with louvers on the hood from the factory, since it is actually a 5.9 yet factory fitted with the 5.2 engine, in traffic i do see the heat mirage escaping through them
water pump is good, relatively new, less than 10k miles
the fan shroud, well, it looks good, i removed it the other day to water spray and clean the inner fins of the radiator, it looks good, there is some gap about 5mm (0.19 of an inch) approximately, btw the shroud has these 4 rubber flaps which are (i guess) for letting the air pass if the Jeep is in highway speed or something !!
the efan, well, it works for now, i mean it is keeping the temperature ranging around the 200 ~ 212, yet what i am not sure about is: it works only in the high speed, now, is this because the fan itself or is it a relay ? btw in the relay and fuses box in the engine, there is the fan relay (or fuse 60 amps), and next to it there is an empty slot, on the fuse box cover the designation of this empty slot is blacked out, i didn't do it for sure so i am guessing it is something done at the factory, i tried to read it and it says "cooling fan" and the fuse rating isn't clear and i couldn't read it
for the coolant, do i need to drain and flush the whole system ?
weighing the options, i am contemplating more on keeping the factory set-up and make sure everything is in order.
the factory fitted these ZJs with dual core radiators for this region here, anyway i will be replacing the radiator with a new one soon.
how to ensure there's no air ? i always check the coolant reservoir and add if needed, and i only open the radiator cap when the engine is cold. is there a thing i can do to check if there is air in the system ?
thanks again
WhatsApp Image 2021-06-01 at 09.48.20.jpg   WhatsApp Image 2021-06-01 at 09.48.22.jpg   WhatsApp Image 2021-06-01 at 09.48.22 (4).jpg   WhatsApp Image 2021-06-01 at 09.48.21.jpg
please take a look at my posts maybe you can help me, i always appreciate any feedback, thank you.
HassZJ1998 is offline
post #30 of 72 Old 06-02-2021, 06:25 AM
StPaul59
Question for polka, how does the controller know when to shut the fan motor off? It doesn't appear to be wired into an on-off switch or am I missing something? I'm guessing maybe that cool down to the radiator happens Within several seconds and it shuts off anyway..
StPaul59 is offline
