4.0 to 5.2 should I - JeepForum.com
 7Likes
post #1 of 24 Old 04-11-2019, 09:03 PM Thread Starter
Ndheep
4.0 to 5.2 should I
I have two 98's one with the 5.2 runs good but had body problems and electrical issues. Just bought the other 98 with the 4.0 in it. The trans lost reverse on the second day of owning it. I could take the parts I need off the 4.0 and put on the 5.2, but it is rusty. The 4.0 Jeep is in much better shape and doesn't have things I don't care for like a sunroof.
The brown one is the 4.0 and the primer gray is the 5.2.
Motor swap or body swap?
98 Grand Cherokee limited 5.2 pos
98 Grand Cherokee Laredo 4.0 parts rig
Ndheep is offline
post #2 of 24 Old 04-11-2019, 09:13 PM Thread Starter
Ndheep
Better pic of the 5.2
Ndheep is offline
post #3 of 24 Old 04-11-2019, 11:57 PM
Timo_90xj
Timo_90xj's Avatar
If you wanted to swap the 5.2 to the 4.0, you'd need to swap the engine, tranny, I'd highly suggest swapping axles as well (d44a rear and both axles having 3.73 instead of the 3.55s on the 4.0), you would need the PCM and most of the wire harness, etc.. and having electrical problems in the 5.2 it's likely those problems swap along with the engine/ tranny/ pcm/ wire harness.
Also keep in mind the 42RE behind the 4.0 does not share the same bellhousing and bolt pattern as the 44RE behind the 5.2 - 4.0 uses AMC and 5.2 is a Mopar.
Looking at the rust on the 5.2 rocker, I'm pretty sure that's just the easily visible part of the rust issues. It more than likely has enough underbody rust on the floor pans, uniframe rails, CA mounting brackets etc. that's it's not even worth fixing at that point. If it has severe rust at or near control arm mounting brackets, it is an actual safety hazard to drive it.
***Under construction***
Timo_90xj is offline
post #4 of 24 Old 04-12-2019, 12:13 AM
IMMORTEN
IMMORTEN's Avatar
Correct me if I am wrong; but wouldn’t it be more feasible to sell off both of those and buy one good ZJ?
I mean I see decent running examples of ZJs for sale here in Denmark for €2500 - €4000
I can imagine (without having it confirmed) that you could get that if you sell both of those ZJs you have...maybe as parts if needed.
Just my input
Sent from my iPhone using Tapatalk
Wojoe likes this.
IMMORTEN is offline
post #5 of 24 Old 04-12-2019, 07:41 AM Thread Starter
Ndheep
The 5.2 is rusty. The doors are off a 94 gc it's kinda a pile. But it does have a rebuilt 5.2 and I swapped in a np 231.
I can't sell the 5.2, It"s title isn't clean. could sell as parts but won't get much for it. The 4.0 has a bad trans. Around here it won't get much either. I paid $500 with it running and driving.
I have a hp d30 to swap in and might just change the gears to 4.56 because i will need to re gear it anyways. The d44a will be swapped in also.
I have both so what ever needs to be swapped I have it or I will replace it with new. Most of the electrical problems are inside. Engine and trans work great
Wojoe likes this.
Ndheep is offline
post #6 of 24 Old 04-12-2019, 08:29 AM
HighLonesome
HighLonesome's Avatar
First, I would rectify the transmission problem in the 4.0 and have a running vehicle.
cpeters1965 likes this.
HighLonesome is offline
post #7 of 24 Old 04-12-2019, 08:30 AM
CatSplat
CatSplat's Avatar
1994 ZJ
In addition to the above, I believe you would need to weld 5.2L frame-side motor mounts to the 4.0L's chassis.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 17" JK Moabs | 32" BFG MT KM
The Jeep of Theseus
CatSplat is online now
post #8 of 24 Old 04-12-2019, 08:53 AM Thread Starter
Ndheep
The trans in the 4.0 lost reverse. It would need a full rebuild. Not willing to do that. Plus the motor has a knock to it.
The 5.2 runs and drives.
Sent from my Vivo X using Tapatalk
Ndheep is offline
post #9 of 24 Old 04-12-2019, 09:39 AM
IMMORTEN
IMMORTEN's Avatar
Ah I see, thank you for clarifying that
IMMORTEN is offline
post #10 of 24 Old 04-12-2019, 09:42 AM
IMMORTEN
IMMORTEN's Avatar
4.0 to 5.2 should I
Is it expensive / feasible to pull a 4.0 transmission out of a wreckers yard?
My 4.0 has kind of a knock to it as well, mainly when cold, I think it just needs a good service, I’m having it in for service on Monday anyway
IMMORTEN is offline
post #11 of 24 Old 04-12-2019, 09:54 AM Thread Starter
Ndheep
I'm going to use the 5.2 no matter what. It is a motor swap or I part out the 4.0
Ndheep is offline
post #12 of 24 Old 04-12-2019, 11:01 AM
FlamingRain
From what I understand, the knock on initial startup in the 4.0 is usually just piston slap and is not a huge problem.
It seems like you've decided what you want to do, and it seems like you want to take on the project of putting the 5.2/44RE behind the body of your 4.0, and whatever axles and other mounting work comes along with it.
2wd can really get you places you can't get out of without 4lo. - Ratmonkey
FlamingRain is offline
post #13 of 24 Old 04-12-2019, 11:04 AM
kg6mov
Hears the voices
kg6mov's Avatar
Mounts bolt on, but yeah, you gotta swap to the 5.2 frame mounts.
If you've got a lot of free time, then 4.0 shell looks to be in better condition. It's not a quick swap, but you've got all the parts you need to make it work.
We can't really tell you what your time is worth. You gotta decide what you want to come out with and how to get there.
kg6mov is online now
post #14 of 24 Old 04-12-2019, 11:05 AM
IMMORTEN
IMMORTEN's Avatar
Okidoki then
Will you keep us posted on the swap?
Would be interesting to see
IMMORTEN is offline
post #15 of 24 Old 04-12-2019, 11:11 AM
1996maroonzjf
Just because it lost reverse doesn’t necessarily mean it needs a full rebuild even though most if not all trans shops will recommend that.
Will a full rebuild fix the problem? Of course, but it could be a rather minor issue fixed by replacing the electronics doing multiuple fluid changes and adjusting the bands.
I don’t think anyone has mentioned that most of the A/C components are on the opposite side of the engine in a 5.2 ZJ. There are so many other little things that you will need to change that make it not practical.
Even if you need a full rebuild it will be cheaper and quicker than attempting to swap a 5.2 in a 4.0 shell
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is online now
4.0 swap McSyd Jeep CJ Forum 24 04-08-2019 10:16 AM
The 5.2/5.9 swap guide for YJs SunDevilJeeper YJ Wrangler Technical Forum 153 12-29-2018 10:50 PM
4.0 and 5.2 tie rod ends difference? Mark-318-IT ZJ Grand Cherokee Forum 19 05-19-2018 04:35 AM
4.0 to 5.2 swap help 08kgraves ZJ Grand Cherokee Forum 15 03-08-2018 09:01 PM
Another 2.5 to 4.0 question Jhanner1 TJ Wrangler Technical Forum 2 12-14-2017 08:45 AM
