360 build advice - JeepForum.com
post #1 of 10 Old 07-26-2017, 02:01 AM Thread Starter
dflewelling
360 build advice
Hey guys.
Im currently rebuilding a 360 for my 98 5.9. It currently has a decent used motor i swapped in after i first bought it. Looking to build up for a bit more oomph while im in there.
No 7 and 8 cylinders are scuffed, so ill probably have to go .030 over. Pistons are probably going to be KB107s unless i can be swayed by something better. I plan on still running premium so i could make the most from more compression.
The heads are cracked between the valve seats (engine only had 87k on it) so im looking into EQ heads. Anyone know who has best price?
Paired with heads, ill probably get 1.7 HS Roller rockers.
I know nothing about cams that would help me choose an upgrade.
Anyone know how to make some good power?
Sent from my SM-G935V using Tapatalk
dflewelling is offline
post #2 of 10 Old 07-26-2017, 02:11 AM
kg6mov
Hears the voices
kg6mov's Avatar
That's basically the ticket, talk to a tuner, I think it's pretty much chris tuned these days since flyin ryan isn't doing jtec.
Not a bad idea to ditch the kegger if you can.
kg6mov is offline
post #3 of 10 Old 07-26-2017, 02:13 AM Thread Starter
dflewelling
First off who is chris and how do i get ahold of him? I had not known that flyin ryan was out. How about hemifever?
Also the hunt for the elusive M1 efi intake is fruitless at reasonable cost.
post #4 of 10 Old 07-26-2017, 06:03 AM
Mopar4U
2016 KL Cherokee
Jeez, what happened to cause piston/cylinder damage and head damage at low mileage? The mopar 318 and 360 were good power plants.
Mopar4U is offline
post #5 of 10 Old 07-26-2017, 10:33 AM
HighLonesome
HighLonesome's Avatar
About the heads, I think Clearwater via ebay is the cheapest. But I would have a shop go over them and that will cost. I would think if you got assembled heads from Hughes they would be ready to bolt in.
Be careful about choosing a different cam because there are so many factors involved. You could end up with nothing but a lighter wallet. A 5.2 cam and 1.7 RRs should give you a little bump without too much thinking. Make sure the cam is hydraulic roller type. Some notes say the cam will work with stock valvetrain and no computer changes needed. Other cams need the heads machined, different springs, torque converter etc. You need to decide how far you want to go keeping in mind bigger cams give you more power up high.
Before I totalled my last ZJ, I was looking into the Crane 2020 or 2030 grind. Very little out there about them. Also the Comp 250 and 256 grinds. I know the Comp 256 and 264 are mentioned on speedfreaks. And there is the Hughes stuff of course.
HighLonesome is offline
post #6 of 10 Old 07-26-2017, 11:03 AM
kg6mov
Hears the voices
kg6mov's Avatar
He's here: [email protected]
I've just never heard good things about hemifever tuning. Canned tunes really aren't the way to go.
kg6mov is offline
post #7 of 10 Old 07-26-2017, 01:50 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Email or contact kolak from my sig.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 10 Old 07-26-2017, 02:20 PM Thread Starter
dflewelling
Previous owners daughter ran out of oil due to bad plenum, combined with low octane fuel. Blew a hole in no 8 cylinder, scuffed no 7 and 8.
post #9 of 10 Old 07-26-2017, 02:28 PM Thread Starter
dflewelling
Do clearwater heads address the cracking between valve seats? What do they flow vs stock vs eq?
post #10 of 10 Old 07-26-2017, 04:18 PM
PolkaPower
PolkaPower's Avatar
The m1s I've seen on FlyinRyans Facebook page are going for around 600.
PolkaPower is offline
