2 suspension questions. - JeepForum.com
post #1 of 9 Old 06-17-2015, 08:44 PM Thread Starter
BaileysZJ
1994 ZJ
I got an alignment on my 94 ZJ today all went well except 2 things. #1) my castor angle is off. Can I just get adjustable lower arms or do I need the upper and lower. And #2) my camber is also out of spec. He said I would need "extended upper ball joints" which sounded weird to me. Does this mean I need new ball joints or is there actually an adjustable version that I have never heard of before. Thank you in advance!!
BaileysZJ is offline
post #2 of 9 Old 06-17-2015, 09:14 PM
kg6mov
Hears the voices
kg6mov's Avatar
There are offset balljoints, mainly a problem on XJ's IIRC that had the c's welded on wrong. You shouldn't need them on a zj unless you bent the axle.
Uppers and lowers to do it right. Just uppers will let you get your pinion angle back.
kg6mov is offline
post #3 of 9 Old 06-17-2015, 09:49 PM Thread Starter
BaileysZJ
1994 ZJ
OK thanks. I hope my axle isn't bent, it looks fine. Any way to test if it's bent? Also if there's no real way to change the camber should I replace the ball joints anyway, could they just be bad?
post #4 of 9 Old 06-18-2015, 12:11 AM
Kolak
Vendor
Kolak's Avatar
How many miles on your Jeep? It's likely your camber is off simply due to worn out stock balljoints.
And how much lift do you have if any?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #5 of 9 Old 06-18-2015, 12:30 AM Thread Starter
BaileysZJ
1994 ZJ
I have 189k on an OME HD lift, pro comps to match. I'm not sure if the ball joints have been replaced before, it might just be that time.
post #6 of 9 Old 06-18-2015, 04:36 AM
PolkaPower
PolkaPower's Avatar
If you look at a stock ZJ axle, you can see that the C's are not straight up and down. They are like |/ ------ \|(vertical lines are the tires, angles are the C's). When you lift it you increase the angle of the stock arms and move the axle inward towards the rocker.
This causes the axle to rotate forward so the angle of the C's are now rotated forward more which causes the camber to be off.
To fix this you need either offset ball joints or adjustable control arms to get the axle back as close to stock position as you can. Sometimes both. Adjustable arms will allow you to get the castor set back near stock too. I never worried too much about the camber, especially at that height.
PolkaPower is offline
post #7 of 9 Old 06-18-2015, 01:45 PM Thread Starter
BaileysZJ
1994 ZJ
OK. That clears things up. I'll get a nice set of adjustable upper and lower arms and hopefully that fixes the camber but if not, oh well. Thanks guys!
post #8 of 9 Old 06-18-2015, 03:40 PM
Kolak
Vendor
Kolak's Avatar
IRO makes excellent quality adjustable arms. PM me if you'd like pricing.
or
Kolak is offline
post #9 of 9 Old 06-18-2015, 10:52 PM Thread Starter
BaileysZJ
1994 ZJ
will do! Thanks again
