1998 jeep gc won't start - JeepForum.com
 1Likes
  • 1 Post By winging it
post #1 of 10 Old 09-04-2019, 04:46 PM Thread Starter
thorpe991
So 2 months ago my inlaws gave me this 1998 grand cherokee 5.2 v8. It didnt start an had no connection from the pcm. Hasn't ran in 3 years. Been doing research an found multiple issues that could cause this. Iv changed the crank postioning sensor, changed the 20amp fuse in the pdc. Has fresh fuel. Battery is new. It cranks but wont start. But i now have connection from the pcm. The fuel is pumping to the engine. After a minute of cranking you can smell fuel up front from the throttlw body. At wot while cranking you can hear a popping noise from the intake but its random. My next thought is bad coil/ plugs/wires. Is there anything else it could be? Am i missing somthing obvious?
Sent from my LG-G710 using Tapatalk
thorpe991 is offline
post #2 of 10 Old 09-04-2019, 04:59 PM
winging it
The first thing that I would do is disconnect and clean the engine bay ground connections. That is each and every large gauge wire connection that goes to the body, chassis, or engine block. I would also recommend upgrading your battery cables, terminals etc etc.
If you do this you will definitely save time and money on sensors that are reading false problems because the voltage is being diminished by bad connections. Good luck!
GW
Spetie likes this.
winging it is offline
post #3 of 10 Old 09-04-2019, 05:55 PM
jtec
jtec's Avatar
2014 JK Wrangler
need to check fuel pressure with a gauge post PSI.
Is there spark at several plugs when cranking?
Have you looked at plugs? might be a time for a fresh set after several years, same fro cap and rotor.
jtec is offline
post #4 of 10 Old 09-04-2019, 07:23 PM Thread Starter
thorpe991
Havent checked plugs yet was more worried with the computer not connecting.
post #5 of 10 Old 09-04-2019, 07:25 PM Thread Starter
thorpe991
GW
The grounds are all clean. The terminals look rough but no corosion
post #6 of 10 Old 09-05-2019, 10:52 AM
jtec
jtec's Avatar
2014 JK Wrangler
not connecting - how did I miss that IDK
check cavity 16 of DLC is there 12volts?
Does the CEL come on at every start for @ 3seconds then go out?
jtec is offline
post #7 of 10 Old 09-05-2019, 04:45 PM
RepBolt
I had replaced my battery terminals recently since it was corroded.
RepBolt is offline
post #8 of 10 Old 09-05-2019, 04:46 PM
RepBolt
It could be the crankshaft sensor, cam sensor, fuel pump or ignition sensor. In my case, it was the ignition sensor.
RepBolt is offline
post #9 of 10 Old 09-05-2019, 09:03 PM Thread Starter
thorpe991
Crankshaft sensor has been replaced. Just seen that the diatributor has a plate in it that senses the camshaft postion an if that brakes it can destroy the distributor. Sunday im taking the distributor off an checking that
post #10 of 10 Old 10-17-2019, 03:20 PM Thread Starter
thorpe991
so i got it running. it was the fuse for the ecu an a very corroded rotor an cap. after changing those it fired up with no problem. then got a code for the governor pressure sensor/ solenoid. replaced those no more code. Now im replacing brake lines front to back. Only issue i haven't figured out yet is that my door speakers will not play. I replaced the radio with a jvc head unit i had from one of my old vehicels. hooked up the remote turn on wire of the radio to the infinity amp turn on wire. i have sound from the tweeters but nothing from all 4 door speakers. haven't pulled the door panels off yet to see if sombody unplugged the speakers. all the wires going to the amp are plugged in. i tested to see if the tweeters were seperate from the amp before hooking up the amp turn on wire an no sound came out of those till the amp was hooked up. so i know the amp is working.
Tomarrow i will be pulling door panels an taking a set of my extra 6.5 coaxial speakers with me to test if the speakers are just bad.
