1998 front axle ABS tone ring - JeepForum.com
post #1 of 5 Old 02-13-2020, 08:59 AM Thread Starter
Zilliver
Hey guys,
I need to replace the axle, the CV is clicking.
I have some spare CV axle but I dont know if the ABS tone ring is the right size, all pictures in the web- it seems wider.
Can anybody comment?
Click the pic for bigger size:
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #2 of 5 Old 02-13-2020, 09:20 AM
Timo_90xj
Timo_90xj's Avatar
Looks normal to me. The shaft on the left has an OEM tone ring that I removed from my 5.9 CV shaft & installed on the cromo stub:
***Under construction***
Timo_90xj is online now
post #3 of 5 Old 02-13-2020, 11:46 AM Thread Starter
Zilliver
Thanks Timo, I will give it a try tomorrow.
Zilliver is offline
post #4 of 5 Old 02-14-2020, 08:40 AM
LordHobbit
LordHobbit's Avatar
Yes those tone rings are replaceable. Spicer sells them individually if you need to replace one. I added rings to the XJ axle shafts that I harvested from the HPD30 I have now.
https://www.amazon.com/Spicer-44646-.../dp/B018OGFF5Q
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #5 of 5 Old 02-15-2020, 02:02 AM Thread Starter
Zilliver
It worked out great, the spare axle shaft is working good
Lower one, is the bad clicking one. Also can see the wider tone ring.
Also replaced the idiotic 12-point OEM bearing bolts.
Zilliver is offline
