1998 4.0 stalling randomly - will refire every time - JeepForum.com
 1Likes
post #1 of 28 Old 02-11-2020, 01:48 PM Thread Starter
8v-of-fury
So it all started sunday morning. Started and drove fine, parked it for 4 hours while I roller skated at the roller rink and come out to just cranking, no fire.
Turn the key off and back on, listen for the fuel pump. Its priming. Still just crank, no fire. I thought what the hell, I'll give it some throttle to see if it changes anything. The 4.0 roars to life after a crank or two - weird. Drives fine rest of the day.
The next day, start it up normally and begin to clear the snow off of it. Stalls while idling. Wth, never has it ever done that before.. lean in turn key, fires right up. Runs fine rest of the day.
Today, no issues starting or driving. Except after a few minutes from the house it stumbles and stalls while trying to accelerate through town. Won't refire again without throttle. Dies once, starts and runs fine. Stumbles once more after another key cycle.
Get home, no codes. Nothing off that I can see..
I recently replaced the plugs because it was near time and it had a small miss and extended crank to start. Plugs seemed to fix those other issues.
'98 ZJ 4.0/242, Locked d30/d35, 31x10.5x15, 2" BB w/ Bilstein 5100's
8v-of-fury is offline
post #2 of 28 Old 02-11-2020, 01:49 PM Thread Starter
8v-of-fury
Kinda seems ignition related? Cause it just dies off hard. No decline and then off, just bam engines off.
It has happened hot, and stone cold. Very odd
post #3 of 28 Old 02-11-2020, 02:08 PM
jtec
jtec's Avatar
2014 JK Wrangler
replaced plugs, tell us what brand and type.
You said no codes - how did you determine that - a scanner?
Engine Turning off, NO codes, restart without lots of cranking I would think about CKP.
Last time changed? troubleshooting vs replacing I error toward replacing CKP be sure to use a OEM component.
jtec is offline
post #4 of 28 Old 02-12-2020, 07:22 AM Thread Starter
8v-of-fury
I do believe I used champion coppers.
Yes, determined no codes with a full read scanner.
CKP is crank position sensor? It's never been changed as far as I know. Jeep has 316k kms.
post #5 of 28 Old 02-12-2020, 08:14 AM
MrRoundel
Well, FWIW, I had to change my CKP last year when my '98 4.0L ZJ had around 320,000 kilometers. And I think that mine outlasted those of many. I knew it was about time. And when my ZJ died while backing out of my driveway, I installed the one I had in my parts drawer.
As was suggested, and is really important, use a Mopar branded part. You really don't want to be replacing this thing anymore than once per 330k kilometers.
There are tips posted on the forum as to what extensions to use on your ratchet, etc. Pay attention and you'll only bloody a few knuckles. Good luck.
1998 Laredo 4.0L 4x4, 242 TC. Turned over 200K miles in 06/18. Original owner.
MrRoundel is offline
post #6 of 28 Old 02-12-2020, 09:22 AM Thread Starter
8v-of-fury
You'd think stalling from a loss of crank position would definitely light up a code, how primitive these things are.. lol
Odd how putting my foot in to it will cause it to catch and fire up as well.
post #7 of 28 Old 02-12-2020, 08:50 PM Thread Starter
8v-of-fury
I just though of something I think i failed to mention, on the one stall while driving it bucked and backfired a time or two, possibly in to the intake is what it sounded like. But with both manifold being there..hard to tell really.
Is that common with a ckp failure? because is looses when it should fire the coil right?
post #8 of 28 Old 02-13-2020, 10:57 AM
terpsmandan
An issue we had with the 98 4.0 was that on cold start, we have to cut and fill from where we park to the narrow driveway. Shifting back and forth from R to D would cause it to stall and it would be very hard to start without a lot of throttle. Never an issue cold starting, just this. We replaced the cap and rotor and now it doesn't stall. Was the cap and rotor worn just enough to cause bad contact when cold and the transmission created just enough drag when going from R to D to cause it?
terpsmandan is offline
post #9 of 28 Old 02-14-2020, 10:55 AM Thread Starter
8v-of-fury
Hmm, the cap/rotor/wires have about 45k kms on them. But I never pulled the cap to check, so I will do that.
post #10 of 28 Old 02-14-2020, 04:58 PM
F1wanab
The crank position sensor and/cam position sensor will cause the engine to shut down, And restart as if nothing has happened.
I had this random shutdown problem and eventually traced it to the crank position sensor. No codes available via the odometer, but apparently some code readers will identify codes.
These sensors are basically proximity switches relying on magnetic fields. With time, the "perminent" magnet becomes weaker and they begin to randomly fail and recover, with increasing frequency.
When the PCM gets no crank or cam position signal, it shuts off the fuel injection. Which is why when the engine comes back to life, there's no coughing or smoke ie just like nothing ever happened.
Not sure about your misfire, perhaps a separate problem.
F1wanab is offline
post #11 of 28 Old 02-16-2020, 08:25 AM
LouC
2007 WK
This is a pretty well known problem if all the sensors are good and your grounds and battery cable clamps are tight and clean, it can be bad solder joints in the engine PCM. I had this on mine back in 2012, went round and round checking things, only thing left was the PCM, had a Mopar unit installed and not one stall since.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #12 of 28 Old 02-17-2020, 09:49 AM
MrRoundel
A few years back my '98 let out a nice backfire when I was going a steady 50mph or so. I pulled over and thought about my 35 mile drive home after such an explosion. When I pulled the codes, a P0351 was thrown, IIRC. That pointed to a bad coil.
My coil was original on what was a 195K mile 4.0L Jeep so I replaced it with a Standard Motor Products coil. After doing so I read that this most often is the sign of a failing PCM, so I replaced the PCM with an Ebay/Junkyard unit. Not knowing for sure that my PCM was bad, I stuffed my it under my back seat for a spare. After all, I knew the car would at least run with it, as it got me home after backfiring that day. All that said, the fact that yours didn't throw a code on that backfire seems odd. Good luck.
post #13 of 28 Old 03-09-2020, 09:32 AM Thread Starter
8v-of-fury
So here is what has transpired. It can do the stall 10s in to running.. I can drive across town and have some stutters along the way while under power or i can drive it all day long with 30 start/stops and have no issue. Not even a hiccup.
I cleaned the distributor cap and rotor, which weren't overly dirty/corroded anyway. I also replaced the Crank Position Sensor with a new BWD unit, no it wasn't a mopar one.. but who has that cheddar? lol It started up and seemed great for the first ride. I was certain we had it. NUOPE. Stalled on me 3 minutes in to the second drive, the next day.
I aggressively wiggled every single electrical connector i could get my hands on in the engine bay, no change. no stutters, no stalls.
I had another aggressive back fire the other day, the engine started to stutter itself down in the rpms after just making a turn out of a driveway. It stuttered down and then BAMM a giant backfire and off we went. I looked in the mirror to see a CUMMINS worthy cloud of rolled-coal LOL. The black smoke cloud was immense, I have never seen a gas engine blow so much black smoke before. I am flabbergahsted as to whats really going on with this thing. It never shows a code of any kind.
Live Data of the sensors would be good, but i dont have access to a scanner like that. Furthermore wouldnt you just see the sensors (CKP and CMP) stop giving data anyway because the engine stopped rotating?
post #14 of 28 Old 03-09-2020, 09:43 AM
Kcooks12
Kcooks12's Avatar
Hmmm.... prior to your black cloud I was thinking fuel delivery issue. Still think that's on the table, fuel pumps dont always quit all at once. Have you checked your injector spray and volume? Grab six clear glass cups and run the fuel pump for three priming cycles (turn key to run for until you hear pump turn off, then repeat two more times). All six cups should be very similar in volume.
Now for your coal rolling..... I'd guess unburnt fuel getting into the catalytic converter. If the fuel system checks out and you're 100% sure spark is good then investigate a clogged catalytic converter.
Kcooks12 is offline
post #15 of 28 Old 03-09-2020, 01:53 PM
watertrucker
When I was having stalling issues with my ‘98 ZJ 4.0 it acted a lot like yours, backfiring and such. There was once after a big backfire it blew out a cloud of smoke. Finally threw a P0351 code for bad coil. Swapped it out, no change. Read on this forum that is also the default code for a failing PCM. Replaced it, problem solved. Hasn’t stalled or hiccuped since. Has been almost a year.
watertrucker is offline
