1995 ZJ, Drivers power window switch intermittent not working - JeepForum.com
post #1 of 6 Old 02-17-2018, 01:36 PM Thread Starter
digdug18
When the drivers/master switch works, all the windows go up and down flawlessly. But it'll work one minute, then stop working. Wait awhile and sometimes it starts working again or sometimes not.
Is this a common problem? Can someone point me to a flow chart or pinout for the switch so I can diagnose it?
Andrew
digdug18 is offline
post #2 of 6 Old 02-17-2018, 02:22 PM
jtec
jtec's Avatar
2014 JK Wrangler
I would clean up the contacts, check wiring - pinched, pulled, clean... the door to chassis wiring harness is a likely place to look BUT I suspect its the 'door module'
I use 'deoxit' for cleaning like this...
Bristol Tenn I spent years there one summer.
Bristol Va - i miss it.
jtec is offline
post #3 of 6 Old 02-17-2018, 02:27 PM
wingless
wingless's Avatar
1994 ZJ
This topic shows my door jamb wiring repair.
FWIW the OP's '95 does not have a door module.
wingless is offline
post #4 of 6 Old 02-17-2018, 02:36 PM
jtec
jtec's Avatar
2014 JK Wrangler
Another PCM ECM VCM CKP CPS issue.
what do we want to call it? driver door multi function switch, driver door control switch, driver door master power window switch...SO much easier to type.
jtec is offline
post #5 of 6 Old 02-17-2018, 04:49 PM
PolkaPower
PolkaPower's Avatar
Open the door and pull back the rubber wire loom in the door jam and inspect the wiring. This is the most common area for wires to break over time.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #6 of 6 Old 02-17-2018, 10:54 PM Thread Starter
digdug18
Ok, thanks.
digdug18 is offline
