1995 ORVIS 5.2 stumbles when hot then runs fine - Page 2 - JeepForum.com
post #16 of 23 Old 05-26-2020, 07:37 AM
jtec
jtec's Avatar
2014 JK Wrangler
it is a process of test and elimination .
Adding my thoughts following the clues.
1st non sensor/electrical items on my mind;
fuel - pressure leaking down.
Coolant entering cylinder.
Vacuum leaks. and EVAP system leak.
right now valve train has me thiking - more coffee and I will thik on that
jtec is offline
post #17 of 23 Old 05-26-2020, 07:59 AM
jtec
jtec's Avatar
2014 JK Wrangler
when starting cold - the engine needs to crank or fires right up?
When hot - any difference?
jtec is offline
post #18 of 23 Old 05-26-2020, 08:34 AM Thread Starter
88formula
ok it fires right up cold... and fires fine hot if I have it off for less than 15 min... but it has to be really hot over 215-220 and sitting for more than 20min it starts up fine then 5 seconds later it starts to stumble... till you start moving then it straitens out
88formula is offline
post #19 of 23 Old 05-26-2020, 08:47 AM
jtec
jtec's Avatar
2014 JK Wrangler
when it is that HOT soak condition.
Have you tried - turn key to RUN do not start count to 3 then key off now try to start - I am thinking maybe a fuel issue.
and thats an easy suggestion.
jtec is offline
post #20 of 23 Old 05-26-2020, 08:57 AM
PolkaPower
PolkaPower's Avatar
This is obvious but carb cleaner is flammable so take caution.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #21 of 23 Old 05-27-2020, 10:58 AM Thread Starter
88formula
tried all that.... turned key.. waited turned it again... then fired up
post #22 of 23 Old 05-27-2020, 01:25 PM
jtec
jtec's Avatar
2014 JK Wrangler
when you did the priming idea did it still have same issue?
jtec is offline
post #23 of 23 Old 05-28-2020, 06:58 AM Thread Starter
88formula
yes
