1994 Laredo Wiring help - JeepForum.com
post #1 of 6 Old 09-18-2012, 11:21 AM Thread Starter
JackedLaredo
1994 ZJ
I need help with the radio wiring situation in my ZJ. It's getting kind of old driving around with no tunes to listen to. So i need help figuring out which wires are which and where they go.
that photo above is a photo of a hot wire they guy i bought the jeep from ran to the radio he had in it. Its directly from the battery.
So much help would be appreciated in helping me wire it together. Ill post a picture of the deck, i believe its the stock original deck, that i want to put it.
JackedLaredo is offline
post #2 of 6 Old 09-18-2012, 03:28 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
hot direct to batt with an inline fuse close to the batt, ground to chassis, find the acc wire, it'll probably be orange with white stripe or red with white stripe or something. a test light or digital multimeter should help there.
that large plug is the ant wire
pull your own speaker wire, preferably 16ga.
ratmonkey is offline
post #3 of 6 Old 09-18-2012, 07:54 PM
timmay5309
timmay5309's Avatar
This may help for the 94. I agree with Rat, I ran all new speaker wire. If your not up to it though, I cannot tell how badly someone hacked the factory plugs, you can buy plugs for under $10 that plug into the existing wire harness and you can wire the stereo into that:
1994 Jeep Grand Cherokee Stereo Information
Constant 12V+ Pink
Switched 12V+ Purple/White
Ground Black
Illumination Orange/Black
Dimmer n/a
Antenna Trigger Green/Red
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Blue/Red
Rear Speakers 6 1/2" Rear Doors
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Blue
Right Rear (+) Blue/White
Right Rear (-) Blue/Orange
timmay5309 is offline
post #4 of 6 Old 09-21-2012, 04:32 PM Thread Starter
JackedLaredo
1994 ZJ
What is the single black one thats next to the antenna cable?
and i dont have the infinity system...Ill post a picture of the deck, and steps of where to put the wires where would be appreciated!
post #5 of 6 Old 09-21-2012, 04:51 PM Thread Starter
JackedLaredo
1994 ZJ
what goes where??
post #6 of 6 Old 09-22-2012, 01:49 AM
KoreaZJ
1994 ZJ
Verify that you have stock wiring in both connectors.
Plug in connectors Gray to Gray / Black to Black.
Antenna cable goes in the round hole in lower-right rear corner.
GRAY
7 - RD/WT...+12v (memory, always on)
6 - RD/GY...+12v (switched)
5 - OR......(panel lamps dimmer)
4 - DB/RD...Park lamps
3 - DB......RF(-)
2 - RD/GY...LF(-)
1 - (nc)....Mute
BLACK
7 - DB/OR...RR(-)
6 - BR/LB...LR(-)
5 - VT/YL...RF(+)
4 - DG......LF(+)
3 - DB/WT...RR(+)
2 - BR/YL...LR(+)
1 - DB/PK...(antenna up)
KoreaZJ is offline
1994 Laredo JackedLaredo ZJ Grand Cherokee Forum 18 09-08-2012 06:43 PM
1994 laredo lift and rims?? 94grandlaredo ZJ Grand Cherokee Forum 19 05-17-2012 12:49 AM
1994 Grand Cherokee Laredo Carlh ZJ Grand Cherokee Forum 2 04-07-2010 05:37 PM
1994 GC Laredo YJBully ZJ Grand Cherokee Forum 4 09-17-2007 06:41 AM
1994 5.2l GC Laredo Tranny Problem Jalapeno ZJ Grand Cherokee Forum 0 04-10-2002 07:47 PM
