Wrangler Cherokee YJ TJ XJ Dana 35 complete axle,spare shafts, OEM limited slip, 3.55 - JeepForum.com
post #1 of 2 Old 02-14-2020, 08:33 AM Thread Starter
codyYJ
codyYJ's Avatar
So I gathered a ton of Dana 35 parts because I thought I could fix my broke Dana 35 for only a couple hundred bucks. Then after a lot of leg work on my end and a couple hundred bucks, realized my 4.56 ring gear was cracked. So lesson learned what to check first and now I have a lot of Dana 35 stuff to get rid of. Just trying to break even at this point. All prices are OBO. I have all this stuff on CL too, but jeepforum members will get a better price so feel free to make me an offer.
-Disassembled but complete Dana 35 from an XJ. 3.55 gear set and OEM limited slip diff. Brakes are almost new. Both shafts look great and one even still had a ton of assembly lube on it so it must be pretty much new. These are non c clip axle shafts. Everything inside looked clean. No signs of abnormal wear or broken metal. I originally planned to pretty much throw this back together and put it under the YJ.
-$65 for the factory OEM limited slip diff.
-$25 for 3.55 ring and pinion set
-$25 for the set of axle shafts
-$5 for the housing and brakes
-$5 for the OEM rear drive shaft with good spare u joints
-Assembled complete Dana 35 from a Wrangler YJ. 3.07 gear set and open carrier. Look to be good brakes. No shock mounts or track bar mount. Really haven't looked at this one for condition but everything spins freely and easily. Also have OEM rear drive shaft.
-$30 for whole thing or I can pull the brakes or axle shafts for a little less say $20.
-Also have a good spare passenger side c clip axle shaft - $5
$100 for it all.
I live in Irvine but work in Corona. Can meet either place. Feel free to PM me your email for pics or text me 951-415-4194.
Thanks, Cody
codyYJ is offline
post #2 of 2 Old 02-18-2020, 09:48 AM Thread Starter
codyYJ
codyYJ's Avatar
BUMP lowered prices make me an offer for one, a couple or all of these parts. Thanks, Cody
codyYJ is offline
