4.0L: everything but the long block - JeepForum.com
post #1 of 7 Old 05-20-2019, 11:43 AM Thread Starter
brentCJ7
brentCJ7's Avatar
My engine failed, so I am selling everything but the long block from my 2001 Jeep 4.0L inline 6. This engine was used in the following vehicles:
1987–2001 Jeep Cherokee
1993–2004 Jeep Grand Cherokee
1987–1990 Jeep Wagoneer
1987–1992 Jeep Comanche
1991–2006 Jeep Wrangler
This engine is also fully compatible and a very easy swap with Jeep CJ-5 and CJ-7 (like mine) that had the 4.2L straight 6, as it is the same block.
All items are used but fully functional. I'd be happy to provide a picture of any item of interest, just message me. I have listed the part number and manufacturer where appropriate and possible.
PCM, for Manual Trans - P5007147 - Mopar - $350
MAP Sensor - 12569240 - GM - $ 50
Fuel Rail - 5014496AD - Mopar - $ 60
Valve Cover with Cap & PCV - 53020323 - Mopar - $ 75
Heater Coolant Tube - 56398 - Dorman - $10 *unused
Intake Manifold - 4854036 - Mopar - $75
Throttle Body - 53030844 - Mopar - $75
Starter Motor - $70
Alternator - $75
Harmonic Balancer & Crank Sensor - HES9199ED - HESCO - $175
Water Pump - $25
Coolant Thermostat Housing - 53006192 - Mopar - $5
Power Steering Pump - $50 *low pressure tubing connection broken but repaired
Oil Pan - 53020833AB - Mopar - $50
Flywheel - 53020519AB - Mopar - $125
Clutch Set - $75
Distributor - 56027028 - Mopar - $65
Timing Chain Cover - 53020222 - Mopar - $15
Hesco Fuel Pump & Regulator - HESRMFPR1 - HESCO - $175
Bell Housing - 3235824 - AMC (4.2L style) - $125 *works with all 4.2L and 4.0L Jeep I6 engines
Throttle Cable - Mopar - 52079382 - $20
Radiator (x2) - $40 ea
brentCJ7 is offline
post #2 of 7 Old 06-17-2019, 04:26 AM
liquidfluidity
I'd love to see the oil pan. If you can, please send pics to [email protected]
Price shipped to 50701?
Thanks!
liquidfluidity is offline
post #3 of 7 Old 06-17-2019, 11:00 AM Thread Starter
brentCJ7
brentCJ7's Avatar
Thanks!
https://app.box.com/s/6s4lj70a11gje7qmx2g8jlltuj3kx6s8
https://app.box.com/s/eyr74wv367jmg2kqver3fzs29lwi13ey
https://app.box.com/s/2wif4pm2rhjdf1c092qgqtyq35ane16y
brentCJ7 is offline
post #4 of 7 Old 06-23-2019, 11:41 PM
bscanland70
Possibly interested bin the ECU and the wiring harness ?
Sent from my Pixel 3 using Tapatalk
bscanland70 is offline
post #5 of 7 Old 09-11-2020, 01:14 AM
Cpowell
If the Hesco cps is still available I want to buy it.
Cpowell is offline
post #6 of 7 Old 09-11-2020, 08:49 AM Thread Starter
brentCJ7
brentCJ7's Avatar
Yes, CPS is available. Do you want just the sensor or the mounting bracket and harmonic balancer too?
brentCJ7 is offline
post #7 of 7 Old 09-12-2020, 11:31 PM
Cpowell
I want all of it. I have tried to send Pm but it wont let me. Here is my digits. 9one0. 489. 1nine9five. Text first Chris
Cpowell is offline
“Mopar Remanufactured” long block quality? btn TJ Wrangler Technical Forum 5 12-02-2018 05:59 PM
Transmission/Gas lines to block bolts DimebagDave TJ Wrangler Technical Forum 0 03-10-2018 04:38 PM
Block cracked on 4.7 v8 High output block toast? Jeepv8hoUK WJ Grand Cherokee Forum 1 03-05-2018 02:13 PM
Anyone used a terminal block when re-wiring nhltfour Jeep CJ Forum 26 02-25-2018 02:10 PM
AUX Fuse Block - Interior Mounting Ideas regrebierf TJ Wrangler Technical Forum 25 02-16-2018 12:27 PM
