32RH automatic transmission - JeepForum.com
post #1 of 1 Old 10-12-2021, 10:18 AM Thread Starter
urimar
I really need your help guys.
I had to change the TCC solenoid in my 2000 Jeep Wrangler TJ automatic transmission and after removing the valve body I noticed that that the accumulator piston seals are a bit worn out and I can not find them anywhere. Also, I did not see any spring coming out with the accumulator piston and, some how the shop manual shows that there is a return spring that goes with the accumulator piston. I have two problems: finding the accumulator piston seals to replace the old ones and finding out if there is a spring that goes with the accumulator piston or not. I looked for it every where and went swimming in the transmission fluid and I could not find it.
Any ideas????
UriMar
urimar is offline
