Hitch tire carrier - JeepForum.com
post #1 of 5 Old 09-03-2021, 04:04 PM Thread Starter
MuloChico
MuloChico's Avatar
2006 WK
Hitch tire carrier
For sale: Hitch/tire carrier
I made this about a year ago. It worked well but I decided on a different route. The hitch rating is 5,000 lb with a tongue weight rated at 500 lb. The tire carrier is currently set up with a 1.5" spacer (spacer included if needed) to work with stock rims on a 1999 WJ with 265/70r16 tires. It should hold a much larger tire well.
Asking $75/make offer. It is just taking up space and I would like it to go to someone who could use it.
PM me here with offer or for more info
MuloChico is offline
post #2 of 5 Old 09-28-2021, 03:18 PM
peta8368
peta8368's Avatar
2017 WK
Hi,
Is this still available? are there any provisions to reduce rattle or movement? Thank you!
Peter
peta8368 is offline
post #3 of 5 Old 09-29-2021, 11:46 AM Thread Starter
MuloChico
MuloChico's Avatar
2006 WK
Originally Posted by peta8368 View Post
Hi,
Peter
Yes it is available. What I did to eliminate rattle was to put a threaded hole with a bolt and nut on the bottom of the hitch mount, just behind the pin. I tightened it down and had no rattle, even Off-road. I can get a picture of it on Friday if you want. I would do it sooner but I am out of town.
post #4 of 5 Old 09-29-2021, 12:27 PM
peta8368
peta8368's Avatar
2017 WK
If you can take some close up of that, that would be great. Thank you!
Sorry about doing all this as posts, but I don't have the ability to send PMs yet (I guess because I am too new?). Thanks.
peta8368 is offline
post #5 of 5 Old 10-02-2021, 06:42 AM Thread Starter
MuloChico
MuloChico's Avatar
2006 WK
Here are pictures. The first one is of it on my WJ, the second is of the bolt on the receiver. With the bolt tightened and the nut secured I never had a problem with it rattling. I posted the pictures here as I could not attach them to a pm.
