15x8 vs 15x10 rims for 35 12.5 15 tires - JeepForum.com
post #1 of 12 Old 01-28-2017, 05:12 PM Thread Starter
esterelyj
Which of these two size rims will hold a bead better at low pressure? Does anyone have an opinion? I have 35 12.5 15 BFG KM2.
Canada is awesome
esterelyj is offline
post #2 of 12 Old 01-28-2017, 05:20 PM
JimSmith
15x8 for 12.5 wide tires
'98 Chili Pepper 2.5, AX5, 33x12.5x15, 5.13, D30 Aussie, Super 35
JimSmith is offline
post #3 of 12 Old 01-28-2017, 05:24 PM
222Doc
222Doc's Avatar
x2 poor mans bead lock. i run 8psi no issues on rocky slow pace stuff all the time. could get away with maybe 6psi. but have had tire slipping issues at 7.
222Doc is offline
post #4 of 12 Old 01-28-2017, 05:25 PM
pwmac
Been running 7.5" Alcoas for over 13 years. It was a good choice.
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #5 of 12 Old 01-28-2017, 05:31 PM
UnlimtedRubi06
15x8 steelies. I run 7psi no issues.
Sent from my SAMSUNG-SM-G900A using Tapatalk
UnlimtedRubi06 is offline
post #6 of 12 Old 01-28-2017, 06:24 PM
btn
btn's Avatar
The narrower wheel will also be tucked within the sidewalls better and won't scrape against rocks as easily.
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
post #7 of 12 Old 01-28-2017, 08:37 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
8" wide does. I've run both widths.
TheBoogieman is offline
post #8 of 12 Old 01-29-2017, 08:29 AM
Rob80x
I have 10's but only because my Jeep came with them.
Rob80x is offline
post #9 of 12 Old 01-29-2017, 08:46 AM
OldJackTheJeep
I run 10", but have never needed to go below 15 psi.
OldJackTheJeep is offline
post #10 of 12 Old 01-29-2017, 12:32 PM
WilcoTJ
I was really happy when I upgraded from 10" wide steelies to 8" wide alloys.
Sent from my iPad using Tapatalk
WilcoTJ is offline
post #11 of 12 Old 01-29-2017, 08:10 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You're not even really airing down until you're below 15 psi.
Jerry Bransford is offline
post #12 of 12 Old 01-30-2017, 06:41 AM
OldJackTheJeep
Maybe I need a lighter Jeep.
