We've found the best Cyber Monday deals for auto geeks on Amazon - JeepForum.com
post #1 of 1 Old 11-26-2018, 01:15 PM Thread Starter
WiseGuide Deals
Your Bargain Hunter
<div class="mm-section-blo0ck">
If you didnít get around to shopping on Black Friday because you were still in a food coma, there are still a ton of great deals on automotive products for Cyber Monday. Here are some highlights, but you can read the full list on Autpguide.com at the link below!
CHECK OUT ALL THE BEST AUTOMOTIVE CYBER MONDAY DEALS HERE
<span style="font-size: 1.17em;">30% Off NOCO Car Battery Jump Starters</span>
</div>
<div class="mm-section-block">
Just in time for winter, NOCO Car Battery Jump Starters are 30% off. If you donít want to be stranded in the cold while you wait for a tow truck or a friendly passerby to help you jump your car if your battery is dead, having a portable jump starter can be a lifesaver ó and it costs way less than paying a tow truck to do it for you. Portable, compact, and easy to use, every driver should have one in their trunk or glovebox at all times.
Not only can you use the NOCO devices to jump your battery on your own, but you can use them to charge up and of your devices via the USB chargers. A single charge can get you up to 40 jump starts and some models even have a flashlight built in.
</div>
<div class="btn btn-content">BUY NOW</div>
<h3 id="mm-section-1" class="section-header">30% Off Innova Bluetooth OBD2 Reader</h3>
If youíve ever had a check engine light appear on your dashboard, you know the anxiety that comes with it. Luckily, you can save hundreds of dollars by checking the cause of that check engine light yourself using an OBD2 scanner, like the Innova scan tool thatís on sale now for Cyber Monday.
This reader will work with any 1996 and newer car that has an OBD2 port. This is also a Bluetooth reader, so there are no cords involved and you can even use your phone or tablet to check up on your car. That comes with another bonus: the RepairSolutions app gives you estimated repair costs, step-by-step videos and more. Itís 30% off for Cyber Monday, so you end up saving almost $66.
</div>
<h3 id="mm-section-2" class="section-header">63% Off Tekonsha P3 Electronic Brake Control</h3>
We included the Tekonsha P3 Electronic Brake Controller on our list of the best trailer brake controllers, and you can now get this high-end electronic trailer brake controller for <span id="priceblock_dealprice" class="a-size-medium a-color-price">$96.34, which is $163.97 less than normalósavings of 63%!</span>
This trailer brake controller has different settings and modes and also displays output current, battery, brake, and output voltage and warning system alerts on its small LCD screen.
</div>
<h3 id="mm-section-3" class="section-header">20% off Michelin Cyclone Premium Wiper Blades</h3>
Michelin Cyclone Premium Hybrid Wiper Blades
are now on sale for 20% off through December 2. These hybrid wiper blades feature Smart-Flex Technology with multi-pressure point surface contact. As a hybrid wiper blade, the Cyclone Premium lineup is built tough for durable wiping in all weather, including heavy rain, ice, sleet, and snow. If youíre not knowledgeable with hybrid blades, they combine the best features of beam and traditional blades for optimal windshield contact.
The premium rubber on these wiper blades have Dura-Glide coating to provide smooth and quiet wipes. The Cyclone Premium blades come with a Dur-iFlex Cover, providing maximum flexibility and protecting the blade from clogging with road debris, ice, and snow.
Like most Michelin wiper blades, the Cyclone Premium Hybrid blades come with the companyís EZ Lok connector system for easy installation.
</div>
</div>
<h3 id="mm-section-4" class="section-header">20% off Philips CrystalVision Ultra Headlight Bulbs</h3>
<h3 id="mm-section-3" class="section-header"> </h3>
Have you been wanting to upgrade your factory headlights bulbs with something brighter? Nowís the time to do so, with savings on Optilux HELLA Headlight Bulbs and Philips CrystalVision Ultra Headlight Bulbs as part of Amazonís massive build-up to Black Friday. Running now through December 2nd, you can save 20% off on the Philips CrystalVision Ultra lineup of headlight bulbs. These bulbs offer a bright white look, similar to what youíd get with HID headlights. The bulbs also feature a unique blue cap, creating a cool blue effect in the headlampís reflector during the daytime.
Also on sale through December 2nd are select Optiflux HELLA Xenon White and Xenon Yellow halogen bulbs. Itís worth noting these bulbs are advertised for off-road use only, so keep that in mind when purchasing them. Generally when replacing your headlight bulbs, youíll want to swap them out in pairs to ensure a symmetric light beam from both bulbs on the road. Avoid just swapping out one headlight bulb at a time.
</div>
</div>
<h3 id="mm-section-5" class="section-header">Save 15% on DieHard Batteries, Chargers & Maintainers</h3>
<h3 id="mm-section-4" class="section-header"> </h3>
DieHardís batteries and trickle chargers have been getting really positive reviews on Amazon. Theyíve been in the battery business for decades, and their trickle chargers are the perfect tool to have handy if youíre storing your car for the winter, or heading on an extended holiday where you have concerns about your carís battery life. Theyíre 15% off for Cyber Monday.
</div>
</div>
<div class="btn btn-content"> </div>
</div>
WiseGuide Deals is offline
