Yukon free spinning hubs - JeepForum.com
post #1 of 24 Old 02-14-2016, 10:40 PM Thread Starter
Dake
Dake's Avatar
Anyone running them on their Dana 30? Or another kit?
Waiting on my Rough Country lift to sag!
April 2020 pandemic YJOTM
Dake is offline
post #2 of 24 Old 02-14-2016, 11:11 PM
Richard_
Richard_'s Avatar
Seems kind of expensive , what is the advantage of locking hubs ?
Richard_ is offline
post #3 of 24 Old 02-14-2016, 11:13 PM
Steve707
Steve707's Avatar
If you do a solid shaft or permanently lock the cad, you can keep your hubs unlocked when not in use and the drive shaft won't spin.
Steve707 is offline
post #4 of 24 Old 02-15-2016, 06:05 AM
gotswap
Maybe save bit of gas with them unlocked but that is a ton of scratch....I have pondered this as well but for that price couldn't you almost go to a d44 that already has lockout hubs?
gotswap is offline
post #5 of 24 Old 02-15-2016, 09:19 AM
Reno72
Reno72's Avatar
Doing the math any savings on gas would take years to make up the cost. If you're doing it because of vibration from a constant turning DS it would be easier to just fix the problem.
92 Rene, 4.5 RE lift, Currie ARB D44, super 8.8 ARB
YJOTM. 12/15
Reno72 is offline
post #6 of 24 Old 02-15-2016, 11:56 AM
Drednot
Drednot's Avatar
Yeah, I don't get the money spent to eliminate the CAD, and then big bux and mods to stop the driveshaft from spinning again...just to save a few pennies on gas?
91 YJ Sahara, 4.0L, AX-15/NP231, D30/[email protected]
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/[email protected]
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #7 of 24 Old 02-15-2016, 04:31 PM
Cobra Jeep
I do not have the yukon lockouts, but I do have a set of vintage spicer lockouts. The yukon hubs are basically a slightly updated copy of the old spicer hubs.
Converting to lockouts is not just to keep the front driveshaft from spinning when you have a solid passenger shaft. It is also to get rid of the unit bearing hubs. Replacement unit bearing hubs are very expensive, where a set of inner and outer bearings and a seal are a fraction of the cost. Not only that, but you can disassemble the hub and bearings to clean/inspect, and then repack with fresh grease.
I did not buy a off the shelf kit, but instead made my own hub conversion using about 99% junkyard parts. In the end I am very happy with it. I now have solid shafts, bigger u-joints, serviceable wheel bearings, lockout hubs, and bigger brakes.
'93 YJ 4.6L stroker, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #8 of 24 Old 02-15-2016, 06:32 PM
Steve707
Steve707's Avatar
Do you have a build thread for how you did it?
Steve707 is offline
post #9 of 24 Old 02-15-2016, 06:47 PM Thread Starter
Dake
Dake's Avatar
Yea id like to know what you used. That sounds more in my budget
Dake is offline
post #10 of 24 Old 02-15-2016, 08:17 PM
TSEJEEPERS
TSEJEEPERS's Avatar
Interesting.
I know I may be wrong but I thought the only lock outs available that would work with a 5 x 4 1/2 wheel pattern was either after market or Ford Bronco II.
The Bronco II have a much smaller stub shaft than the YJs.
I did run the Warn kit way back when, when I was still running my 30. It did work well and I really did not have any problems with it.
A couple of things to consider though.
The first one is parts. If you brake a lock out the only available one would have to come from Yukon.
The next one would be lubrication. Bear with me on this.
First off all with lockout hubs you are not spinning the U joints, so they are basically just sitting there.
I have to replace my u joints every couple of years (Dana 44) not because they are broke or wore out, but because the needle bearings are rusted.
The other one is the housing itself. Again nothing is turning in two wheel drive, I do change my gear lube every year. Every time there is rust in the housing and on the ring gear. I just clean it up, but I could see where if some one was to let it go it could lead to problems.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 24 Old 02-15-2016, 11:03 PM
TSEJEEPERS
TSEJEEPERS's Avatar
Cobra Jeep
If you do not have a write up pictures would be nice.
What lock outs and spindles did you use?
What knuckles did you use?
Were you able to keep the 5 x 4 1/2 bolt pattern?
post #12 of 24 Old 02-16-2016, 06:18 AM
gotswap
the plot thickens
gotswap is offline
post #13 of 24 Old 02-16-2016, 04:19 PM
Cobra Jeep
I thought I might get this reaction....lol
I do not have a writeup as of yet. I have been meaning to do one but I have been a little lazy about it. Plus I wanted to make sure everything was going to work together ok. So far about 4 months with zero issues. I need to take some time and try to make a writeup.
To answer a few questions:
I did not keep the 5 on 4.5 bolt pattern. Doing it the way I did it converted it to 5 on 5.5.
I am using standard dana 44 lockout hubs, so if one breaks, a replacement lockout will not be hard to find.
I am using a combination of jeep, ford, chevy, and dodge parts. It took quite a lot of research to do it.
When I do my writeup I will detail all the parts I used and what vehicles they came from. Now that I know there is interest, maybe that will get me motivated to finally post it up.
post #14 of 24 Old 02-16-2016, 04:38 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'm still on the old Warn kit. Gas wasn't a consideration, was all off-road concerns. Besides the unit bearing 'fix' mentioned above, I like that pretty much anything can happen to the front half of the drive line on the trail and I can keep going.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #15 of 24 Old 02-17-2016, 12:36 PM
Steve707
Steve707's Avatar
Just curious, are these on the same build with WJ knuckles? Really looking forward to your write up.
Steve707 is offline
