you know you drive a YJ when..... - Page 929 - JeepForum.com
 192Likes
post #13921 of 13923 Old 03-31-2020, 03:57 PM
LlanoTX95YJ
YKYDAYJ When
or you can left turn and treat your passenger: wink2:
LlanoTX95YJ is offline
post #13922 of 13923 Old 03-31-2020, 05:10 PM
jhrebs
1987 YJ Wrangler
Originally Posted by Gallent View Post
YKYDAYJ when your in an accident and you use your winch to help Police pull the other car away from traffic.. while waiting for the tow truck for their vehicle...
Do it all the time in snow storms.
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #13923 of 13923 Old 04-28-2020, 09:11 AM
LlanoTX95YJ
YKYDAYJ when the bolts that hold the power steering fluid reservoir to the radiator thread into welded nuts, ensuring a solid mount and that the nuts will be there when you need them, but the bolts that hold the radiator to the body on the other hand, thread into flimsy little clips, ensuring that at least one will break. Seems bassackwards.
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 04:28 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 02:11 PM
POLL: Ok to Drive w/ rear drive shaft? Libtekguy TJ Wrangler Technical Forum 14 07-02-2008 11:25 AM
