YJ wipers - JeepForum.com
post #1 of 7 Old 05-03-2001, 04:46 PM Thread Starter
goofus
YJ wipers
Is anyone aware of some sort of windshield wiper conversion for YJ's that makes the wiper arms bent like the TJ?
goofus is offline
post #2 of 7 Old 05-03-2001, 06:02 PM
jeffy
jeffy's Avatar
You know, I don't think it can be done. When they built the TJ they moved the wiper mechanics into the cowl instead of having it in the windshield frame. If the wipers on the YJ would have to have an increased arc to fo all the way down. They would them run off the windshield on the driver side and the passenger side wouldn't sweep half the windshield. To get everything working right you'd have to replace the lengths of the swing arms that are in the windshield frame. Then you would have to make sure that the arms don't bind and can still fit in the limited space. I don't think it's worth it. Real Jeeps have wiper blades on the windshield.
*** www.4BangerJP.com ***
jeffy is offline
post #3 of 7 Old 06-30-2002, 07:36 AM
lostboy
Guest
check these guys out:
<a href="http://www.riptech.net/" target="_blank">http://www.riptech.net/</a>
lostboy is offline
post #4 of 7 Old 06-30-2002, 10:06 AM
RCHavok797
RCHavok797's Avatar
I just did the conversion last weekend, its so much nicer having the wipers out of the way.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #5 of 7 Old 06-01-2007, 12:05 AM
chezuki
Beautiful. I love it when a search works out.
chezuki is offline
post #6 of 7 Old 06-01-2007, 12:14 AM
Ares
Ares's Avatar
There are a couple of companies that mad a easy conversion for it, however, I don't recall any of them being cheap.
- Cameron
Ares is offline
post #7 of 7 Old 06-01-2007, 12:29 AM
ZonaWrangler
I have "stowable" wipers on my YJ. I live in Arizona, so I don't need wipers most of the time. First Jeep I ever owned, and the wipers didn't work at all when I bought it ... but I could hear the motor going. I wasn't aware that YJ wipers were supposed to be in the middle of the windshield, so I fixed it ...
I had to lay the windshield down, and I found combs and trash and lighters, that had been sucked in by the YJ Dash black hole. The motor was still going, but not mounted, and the linkage was off. I think ... I may have installed the motor upside down, as it pushes up and away now, rather than across and away ... and on sunny days, I can push my wipers below the windshield frame.
Seriously ... no idea how I did it ... I just made it work. Think I might have mounted the motor upside down.
http://img242.imageshack.us/my.php?image=my95smbe2.jpg
95 Wrangler Rio Grande. Herculined, AEM Brute Force, Helix TBS. No lift, Viper alarm, Primax rims and 30 x 9.5 Dunlop ATs. Gabriel HD shocks. My DD. Mostly ..... mostly.
ZonaWrangler is offline
No Wipers 03 TJ ??? HELP matt240 TJ Wrangler Technical Forum 4 02-14-2009 12:54 PM
tj wipers on an yj sofixj YJ Wrangler Technical Forum 5 03-30-2007 11:08 PM
wipers ute TJ Wrangler Technical Forum 3 04-15-2005 05:50 PM
What Up With My Wipers? GrimJeeper91 YJ Wrangler Technical Forum 8 03-16-2005 01:22 PM
Wipers sevise TJ Wrangler Technical Forum 17 01-24-2005 04:43 PM
