YJ Window Regulator Removal - JeepForum.com
post #1 of 4 Old 05-03-2021, 11:30 AM Thread Starter
94YJ94
94YJ94's Avatar
I have some old full steel doors that have been neglected for decades. When driving home I was rolling my window up (which was back breaking) and about half way up there was a loud crack and it completely froze.
When I got home I took the panels off and tried to do some trouble-shooting. The crank now completely spins freely, but the window doesn't move. Pretty sure the regulator is bent, or a tooth broke or something else is off track.
I am trying to pull the regulator out but the four screws that hold it in place feel like they are welded. Nothing I use right now (aside from trying heat) will work at getting these out. I don't understand how they are so tight, it's an interior door panel sheet-metal screw...
I've attached a picture of the screws in question. Has anyone else had issues getting these out? They are Phillips head screws, and I haven't stripped them out yet, thankfully, but man they are impossible to turn out. Can I fix this without taking the regulator out? It feels like the teeth just aren't lining up, or something is off track when cranking the window crank.
94YJ94 is offline
post #2 of 4 Old 05-03-2021, 03:33 PM
blake989
My regulator only had the four screws, not the lower 5th one. The only thing holding the window up is the regulator, so if the teeth are mis-aligned, I would assume the window would have fell down inside the door. Either way, you have to detach the regulator from the window, and remove the window, before you can remove the regulator.
The famous...gaucho door rebuild
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #3 of 4 Old 05-04-2021, 05:46 PM
fishadventure
fishadventure's Avatar
That’s an awesome thread^^^^
Did the cup that retains the operator shaft bum out? Also, if the tracks come loose that can bind things up.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #4 of 4 Old Yesterday, 08:49 AM Thread Starter
94YJ94
94YJ94's Avatar
Heat was the answer.
I got them out with a torch. Now that I have it out it looks like the crank mechanism is either off it's track or the spline broke, something isn't right. It just makes a clicking sound every time I crank it, and it stays on the same tooth. The crank mechanism is riveted in. I ordered a replacement part and will be installing it instead of the original.
When I broke it trying to roll up my window, I'm pretty confident something cracked.
94YJ94 is offline
