YJ trailer build - JeepForum.com
 14Likes
post #1 of 27 Old 05-30-2020, 08:08 PM Thread Starter
V8orBUST
V8orBUST's Avatar
YJ trailer build
Finally started my trailer project. Figured I would start a build thread. Cut a wrecked YJ in half today to start out. Need to go to the metal yard and get some box for the tongue. Still trying to figure out how to close up the front, thinking a wood frame with stainless sheet metal. I will be using this as a camping trailer. Any ideas or recommendations are welcome.
Few thoughts:
Will have a lunette on the tongue.
Thinking of keeping the gas tank on it with a transfer pump instead of mounting Jerry cans.
If I keep the D35 under it, I can use the emergency brake still.
Open top is easy, closed top is better but will make it hard to reach things up front.
bruinjeeper, Azhunter1 and cpia84 like this.
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #2 of 27 Old 05-30-2020, 08:30 PM
timatoe
timatoe's Avatar
Looking forward to seeing the progress. A buddy and I are planning a similar trailer using a CJ5 tub.
timatoe is offline
post #3 of 27 Old 05-30-2020, 08:44 PM Thread Starter
V8orBUST
V8orBUST's Avatar
make a build thread! Want to see that too
timatoe likes this.
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #4 of 27 Old 05-30-2020, 09:04 PM
bruinjeeper
bruinjeeper's Avatar
wicked. subscribed.
If you never planned on mounting stuff on a hard topped shell like a tent or what not, why not just a tonneau/duster cover? Grab some tub rails and call her done.
If i ever get a chance to do this, i would probably make both ends open up, and keep the family rollbar idea in it (or a variant thereof) for a roof top tent to perch on. It would require another back end of a YJ (from the body seam back).open ended tailgates on either side and simply repurpose a tonneau cover. Unsure how much you want to get involved on this project, but that is a pretty slick and functional option.
Love the idea on you keeping the gas tank. Functional space saver.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #5 of 27 Old 05-30-2020, 11:32 PM
Chrisnvegas
Chrisnvegas's Avatar
There are rear tub sections available that could be either spot welded to the front, welded, screwed, glued, ect.
Having 200 lbs of fuel behind the axle could make for some exciting handling characteristics. The axle is extra weight for not much benefit..
Most standard 5 lug trailer hubs are the same pattern as a YJ. 5x4.5"
Awesome and Azhunter1 like this.
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #6 of 27 Old 05-30-2020, 11:47 PM
92 Green YJ
92 Green YJ's Avatar
You could grab some rear corner patch panels and use them on the front and then drop a CJ tailgate in over the tongue side so you could access from both sides. Or slap the CJ gate on the back to serve as a table and move the YJ gate to the front. Or he’ll, fold down CJ gate on both ends. Would make it easy to access gear from both sides and give you extra “table” space when folded down.
Azhunter1 likes this.
92 Jeep Wrangler Unlimited +
Tons, 40s, tons of mods
92 Green YJ is offline
post #7 of 27 Old 05-31-2020, 12:10 PM
GTS225
I gotta side with Bruin on this. Hit up a salvage yard for a wrecked YJ tub that you can cut the rear section off of. Get from the wheel wells back so that you can extend the front a touch. Weld it all together along with the tailgate up front. This might ultimately serve as a small camping box, if your hitting a 2-day trail.
Chris is right about the imbalance of that much fuel aft of the axle. You might want to stick with Jerries. At least you can move them around in the trailer..
Roger
GTS225 is offline
post #8 of 27 Old 05-31-2020, 02:52 PM Thread Starter
V8orBUST
V8orBUST's Avatar
I like the idea of another rear section, but there are just no available YJ tubs out here. I'll take the suggestion to eventually get rid of the d35 and not put the gas tank on. I considered using my sport bar on it, but this was a rollover jeep and all the mount points have sheared bolts and are badly warped. My budget is somewhat limited so I need to keep new material cost down.
I did weld in a piece of angle near the floor board and roll the floor pan up to it. And had an idea. In the picture I put in a piece of card board where I am considering building a wood plank wall. It will bolt to the vertical section the roll bar bolts to and will be the main barrier all the way up to the tub. This will leave a void that can mount Jerry cans to. Sorry this is a bit low budget, but times are tough and I want to do something with the wrecked parts jeep I have.
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #9 of 27 Old 05-31-2020, 03:15 PM
Awesome
Awesome's Avatar
Build a top for it, but make it hinged in the middle. A top that opens from both ends, if you will. That will solve your issue of not being able to reach things.
The 4th 5-seater YJ in the world.
Awesome is offline
post #10 of 27 Old 05-31-2020, 08:47 PM
bruinjeeper
no need to apologize for being on a budget here... you know us - love to live vicariously through other members' wallets.
i would seriously consider utilizing the family rollcage if it can be had for cheap. can see it coming in plenty useful for mounting brackets and doo dads and equipment to. Grab some tub rails, and a tonneau cover for a top, figure out a way to secure it to your wood plank (maybe snaps?) and your good.
timatoe likes this.
post #11 of 27 Old 05-31-2020, 10:03 PM
RockWoRM
RockWoRM's Avatar
This one got me thinking... r u talking E brake while driving or a brake to keep it in place while parked... like the old WWll Jeep trailers w/hand brake on the tongue?
What, Sean thinking about cutting up the CJ already?
timatoe likes this.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is online now
post #12 of 27 Old 06-01-2020, 03:20 AM
timatoe
timatoe's Avatar
No we have the tub that came with the frame (that were separate in the field we got them from). He got a better tub and frame for $200, we only used the tub because we had already boxed and plated the original frame. We got a free DJ (mail jeep) from another field that we used the grill and windshield frame. So we have two mostly complete tubs and frames, but I think we're going to cut the DJ in half lengthwise and make an outdoor kitchen out of it for his backyard pool / patio area.
RockWoRM likes this.
timatoe is offline
post #13 of 27 Old 06-04-2020, 08:25 AM
FergiesJeep
Fuel is only 6lbs pr gallon so with a 20 gallon tank its only 120 lbs.
I built one of these a while back for a guy, phone was destroyed or i would post a pic. what i felt after much debate was the best way was to buy a set of CJ tub corners for the front so you only had to fill in the light mount holes. you will have to trim the bottom of the sides near the door because they sit about 2 1/2" lower then the back. Then i cut a filler for the back part of the door.
Across the front we ended up filling in the step down because it became a catch all and was a pain. The front panel we used a piece of sheet metal to the rib height and to keep the contour of the top rail i welded in a piece of C channel and cut a strip of metal for the angle piece and welded it in.
We took it a step further and made a popup tent on top that flipped forward onto the tongue so the guy could still access the storage with person in tent downfall was i had to make the tongue longer.
I also did a tailgate conversion from swing out to drop down.
FergiesJeep is offline
post #14 of 27 Old 06-04-2020, 01:02 PM
NHfireLJ
NHfireLJ's Avatar
Sub'd
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #15 of 27 Old 06-08-2020, 08:13 AM
cpia84
cpia84's Avatar
Sub'd!! I really want a camp trailer for my Jeep one day.
Military Trailers have an e-brake handle for each hub, Its a fairly straight forward setup. I am sure one can be made with the existing hardware and transferred to a trailer specific axle.
I will agree with a center hinged top or maybe a drawer system depending what you have available. How tall do you plan on making the trailer or just keeping it level with the tub rails?
I'm very interested to see this progress!
cpia84 is offline
