Yj stretch - Page 3 - JeepForum.com
post #31 of 40 Old 05-21-2014, 06:23 AM
skyj
Wow I've been slacking in my Jeep forum reading lately. Sparrows thanks for throwing mine and the others links up to the dimple tank mod. I have been running mine like this for 2+ years now and not a single problem I did have to modify my pickup tube on my fuel pump (had to shorten it up) since I went to a in tank pump so beware of that. With the heating of the tank you got to take it extra slow that plastic is thick and can't be heated up too fast or you do it will burn a soft spot in it. I have enough room for a 4" stretch which I plan to do in the nearer future by cutting my frame mounts off and moving them back.
And as far as using waggy springs I love mine I used a combination of junk yard waggy springs and a main leaf from and xj. It works and flexes real good, in sua I dont get any axle wrap with the V8
build thread:
skyj is offline
post #32 of 40 Old 05-21-2014, 09:52 PM Thread Starter
YJjeeper90
Originally Posted by YJ4LIFE
I tried it and failed. I punctured the plastic tank. similar suggestions were using '82-02 camaro/firebird gas tank, or a fuel cell behind the back seat.
Do you know if a firebird/camaro gas tank would bolt directly In? Or do you have to cut it up?
1990 YJ 4" RC lift, no track bars or sway bars, 35s, stock axles, MC fenders, tom woods drive shafts, advanced adapters sye kit,
YJjeeper90 is offline
post #33 of 40 Old 05-21-2014, 11:26 PM
skyj
I've heard the camero tank mentioned a few times, but have yet to see one actually used. I'm curious also? Its like an urban legend
build thread:
skyj is offline
post #34 of 40 Old 05-21-2014, 11:39 PM Thread Starter
YJjeeper90
Read another forum were a guy used a geo metro tank! Haha
post #35 of 40 Old 05-22-2014, 09:27 AM
Norcal_chris
Norcal_chris's Avatar
camaro tank
*15 gallons; 57 liters; 33 in. L x 23.38 in. W x 11.38 in. H;
Yj tank
*1987-1995Dimensions: 33 3/4 x 17 x 12
So apparently you could have 6inches more room running the camaro tank.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #36 of 40 Old 05-22-2014, 12:11 PM Thread Starter
YJjeeper90
Originally Posted by Norcal_chris
camaro tank *15 gallons; 57 liters; 33 in. L x 23.38 in. W x 11.38 in. H; Yj tank *1987-1995Dimensions: 33 3/4 x 17 x 12 So apparently you could have 6inches more room running the camaro tank.
Thanks!
post #37 of 40 Old 05-22-2014, 01:45 PM Thread Starter
YJjeeper90
Originally Posted by youngjeepr
I got 3" I used waggys front and rear so I've got a total of 6" stretch.
when you stretched the front how hard was it make the steering work?
post #38 of 40 Old 05-22-2014, 04:56 PM
youngjeepr
youngjeepr's Avatar
I didn't change a thing with my steering
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #39 of 40 Old 05-22-2014, 09:49 PM
YJ4LIFE
http://www.pirate4x4.com/forum/13123080-post97.html
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #40 of 40 Old 05-22-2014, 10:48 PM
skyj
Oh yeah that doesn't look like a hack job lol. Wonder which fuel pump he used and is there enough dimple in it guess I need to go stick my head under a few camero's in the junk yard.
build thread:
skyj is offline
