Yj stretch - Page 2 - JeepForum.com
post #16 of 40 Old 05-20-2014, 08:39 PM
Randonexplosion
Randonexplosion's Avatar
Like they said you don't have to relocate the shackle. The spring is only 1" longer but the center pin is offset by 2".
Randonexplosion is offline
post #17 of 40 Old 05-20-2014, 08:40 PM
TrentYJ
I've seen ppl on pirate use cherokee springs to get somewhere between 4 and 6in of stretch. Can't remember the exact number off the top of my head. Also you can re-drill the centering pin to get the exact stretch you want but let a shop do it unless you want to go through 30 hss bits.
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline
post #18 of 40 Old 05-20-2014, 08:43 PM
Norcal_chris
Norcal_chris's Avatar
xj springs are 6in stretch.
Redrilling leafs is ususally a bad idea. They love to crack at the holes.
Ive drilled a few sets of leaves with a drill press on slowest setting and a quality bit. It doesnt take long.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #19 of 40 Old 05-20-2014, 08:50 PM
TrentYJ
Ah thanks I knew it was one of the two. However, I'm asuming the OP doesnt want to relocate the tank if hes talkin 3in or so. Yeah spring steel's favorite snack is drill bits. by the time I could get through one I've spent almost as much as the spring.
TrentYJ is offline
post #20 of 40 Old 05-20-2014, 09:33 PM Thread Starter
YJjeeper90
ok makes sense now
1990 YJ 4" RC lift, no track bars or sway bars, 35s, stock axles, MC fenders, tom woods drive shafts, advanced adapters sye kit,
YJjeeper90 is offline
post #21 of 40 Old 05-20-2014, 09:42 PM
youngjeepr
youngjeepr's Avatar
He would have to dimple the tank for a 3" stretch.
Sounds like you need better bits and or better cutting fluid.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #22 of 40 Old 05-20-2014, 09:49 PM Thread Starter
YJjeeper90
Originally Posted by youngjeepr
He would have to dimple the tank for a 3" stretch. Sounds like you need better bits and or better cutting fluid.
How do you dimple a tank?
post #23 of 40 Old 05-20-2014, 09:52 PM
youngjeepr
youngjeepr's Avatar
There's a good thread on pirate4x4 on how to do it.
But basically you drop your tank cut a section out of your gas tank skid plate and weld it back on so it forms a pocket right above the dif. Then you heat up your Polly tank and push it back into the skid.
post #24 of 40 Old 05-20-2014, 10:08 PM
YJ4LIFE
I tried it and failed. I punctured the plastic tank. similar suggestions were using '82-02 camaro/firebird gas tank, or a fuel cell behind the back seat.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #25 of 40 Old 05-20-2014, 10:19 PM
Randonexplosion
I don't have a link but 92VegasYJ has a good write up in his build thread.
post #26 of 40 Old 05-20-2014, 10:32 PM
Sparrows
Sparrows's Avatar
So does Sky J. Lemme find the links...
Cheers
June '13 YJOTM
Sparrows is offline
post #27 of 40 Old 05-20-2014, 10:33 PM
Norcal_chris
I did my tank. Used it for a month or so and then went for a bigger stretch. Took the tank about 3 months and it undimpled itself.
I used a propane torch and took my time. 3 cycles of heat and straps did it.
post #28 of 40 Old 05-20-2014, 10:34 PM
Norcal_chris
Post 39
https://www.jeepforum.com/forum/f22/9...13/index3.html
post #29 of 40 Old 05-20-2014, 10:36 PM
Sparrows
Sparrows's Avatar
Links:
https://www.jeepforum.com/forum/f22/j...l#post14863105
https://www.jeepforum.com/forum/f22/s...l#post14856317
I'm halfway through my own dimple mod. Haven't had a chance to heat up the poly tank yet, but welding in the dimple is super easy.
Oh and I stretched mine almost 4" in the back by moving the fixed hanger back around 2.5" (well up 3" which changes the arc of the spring ~1"+, and back 1.5") then used a 1" offset perch on stock springs SOA. Food for thought.
Cheers
June '13 YJOTM
Sparrows is offline
post #30 of 40 Old 05-20-2014, 10:38 PM
Sparrows
Sparrows's Avatar
I'm pretty sure you didn't link directly to the post JUST so I'd have to wade through all those Rubicon pics, causing an extreme amount of jealousy...
Cheers
June '13 YJOTM
Sparrows is offline
