Yj stretch - JeepForum.com
post #1 of 40 Old 05-20-2014, 04:01 PM Thread Starter
YJjeeper90
Yj stretch
Ok so I'm wanting to stretch my jeep when I get axles an everything I'll need I already have metalcloak front fenders so I want to use metalcloaks stretch corners that allow up to 4 inches of stretch. Anyone know of a way I can stretch it 4 inches using leafs? All the leaf stretch kits I find are for 6 inches. I don't mind gathering different pieces to do it. Has anyone done a 4 inch stretch on a YJ using leafs? Thanks
1990 YJ 4" RC lift, no track bars or sway bars, 35s, stock axles, MC fenders, tom woods drive shafts, advanced adapters sye kit,
YJjeeper90 is offline
post #2 of 40 Old 05-20-2014, 04:36 PM
Randonexplosion
Randonexplosion's Avatar
Front wagoneer springs will give you 2" of stretch then you could move your spring hangers back and/or use perches that allow another 1" of stretch. I just got my Rancho 44044s installed and they give about 4" of lift on a YJ. Then there is no need to put your shackles on the rear crossmember.
Randonexplosion is offline
post #3 of 40 Old 05-20-2014, 04:55 PM
YJ4LIFE
i used 52" chevy springs for about 4"
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #4 of 40 Old 05-20-2014, 05:20 PM Thread Starter
YJjeeper90
How do they flex?
post #5 of 40 Old 05-20-2014, 05:26 PM
youngjeepr
youngjeepr's Avatar
I'm not sure about his since he is SUA but my stock height waggy springs are going to flex very well!
The rear springs are hitting my frame (to short of shackles. And my front are clamped to tightly. Also I maxed the engine hoist out before I lifted a tire.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #6 of 40 Old 05-20-2014, 05:32 PM
Randonexplosion
I haven't wheeled them yet but this is the first flex test. They ride nicely too
post #7 of 40 Old 05-20-2014, 05:33 PM
Randonexplosion
They are short side forward right now for other reasons so basically stock wheelbase.
post #8 of 40 Old 05-20-2014, 07:35 PM Thread Starter
YJjeeper90
I like that. Did you just drill new holes in your frame for the shackles?
post #9 of 40 Old 05-20-2014, 07:47 PM Thread Starter
YJjeeper90
Originally Posted by youngjeepr
I'm not sure about his since he is SUA but my stock height waggy springs are going to flex very well! The rear springs are hitting my frame (to short of shackles. And my front are clamped to tightly. Also I maxed the engine hoist out before I lifted a tire.
how much stretch did u get?
post #10 of 40 Old 05-20-2014, 08:07 PM
youngjeepr
youngjeepr's Avatar
I got 3" I used waggys front and rear so I've got a total of 6" stretch.
post #11 of 40 Old 05-20-2014, 08:08 PM Thread Starter
YJjeeper90
how did u relocate the shackles? Just drill new holes?
post #12 of 40 Old 05-20-2014, 08:13 PM
youngjeepr
youngjeepr's Avatar
I didn't relocate them. There is no need to relocate the shackles.. The longer springs just give you a better shackle angle when using the stock spring hangers and shackle mounts.
But I will be frenching my spring hangers into the frame so I can lower my jeep a few inches.
post #13 of 40 Old 05-20-2014, 08:15 PM Thread Starter
YJjeeper90
I didn't relocate them. There is no need to relocate the shackles.. The longer springs just give you a better shackle angle when using the stock spring hangers and shackle mounts. But I will be frenching my spring hangers into the frame so I can lower my jeep a few inches.
Awesome are they the 44044s everyone talks about or a different waggy spring?
post #14 of 40 Old 05-20-2014, 08:20 PM
youngjeepr
youngjeepr's Avatar
I pulled my springs from the junkyard. So they are just factory springs.
post #15 of 40 Old 05-20-2014, 08:27 PM
Norcal_chris
Norcal_chris's Avatar
A lot of people run 44044s . They are an excellent spring a do flex well. I think they are perfect for an SUA jeep that wants some stretch.
I redrilled my spring perches an inch back when i had my 8.8 SUA. With those 44044s and a 1inch back drilled hole in your perch, and u bolt plate you could get an easy 3 inch stretch.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
