YJ Steering issues - JeepForum.com
 1Likes
  • 1 Post By jbolty
post #1 of 11 Old 12-16-2020, 09:44 AM Thread Starter
pjhpatrick
YJ Steering issues
I have a '92 YJ with 234k miles, which I bought this year. I have replaced the upper and lower ball joints, the tie rod ends, and had the front end professionally aligned. However, the steering still "wanders" (I did not replace the pittman arm. and haven't touched the steering box). Any suggestions would be appreciated.
pjhpatrick is offline
post #2 of 11 Old 12-16-2020, 10:37 AM
Randonexplosion
Randonexplosion's Avatar
Do you have lift shackles up front? Stock length are 4" bolt to bolt.
Sent from my SM-N975U using Tapatalk
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is online now
post #3 of 11 Old 12-16-2020, 10:52 AM
jbolty
Administrator
jbolty's Avatar
what he said, what shackles. incorrect caster angle can cause wandering as well as wrong toe.
FYI. having a YJ professionally aligned really means nothing. The only thing adjustable is toe in which can be done at home in 15 minutes. No place other than a dedicated offroad shop is going to do anything with shiming for caster and camber can only be set with adjustable ball joints, but there is never any good reason to use those.
Randonexplosion likes this.
jbolty is offline
post #4 of 11 Old 12-17-2020, 01:37 AM
timatoe
timatoe's Avatar
How does the steering feel? I mean is it responsive, is there a lag, any significant play etc.
timatoe is offline
post #5 of 11 Old 12-17-2020, 07:56 AM Thread Starter
pjhpatrick
Steering is not responsive ... when turning steering wheel, there is about a 5 degree difference between turning the wheel, and the response from the tires. Play is also about 5-10 degree
post #6 of 11 Old 12-17-2020, 12:18 PM Thread Starter
pjhpatrick
I don’ t have any lift “wedges”, if that’s the same thing as shackles.
post #7 of 11 Old 12-17-2020, 01:31 PM
Randonexplosion
Lift blocks are only applicable in a "spring over" setup, YJs came out of the factory with the springs under the axle.
The shackles are what connect the leaf spring eye to the frame in the front and rear of the vehicle. Installing longer shackles is a quick way to get a small amount of lift but up front they can affect your caster angle, making your steering wander and defeating the self centering of the steering wheel.
post #8 of 11 Old 12-17-2020, 01:56 PM
fishadventure
fishadventure's Avatar
How is the steering column bearing and its ujoints?
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #9 of 11 Old 12-17-2020, 07:44 PM
93YJfalcon
https://www.ruffstuffspecialties.com/R2008.html
This may help.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #10 of 11 Old 12-17-2020, 09:57 PM
jbolty
Administrator
jbolty's Avatar
before you do anything post some pictures of what you have. meantime have a friend rock the steering wheel while you look over everything looking for play. engine off
don't start throwing parts and labor at it until you know what's wrong
jbolty is offline
post #11 of 11 Old 12-18-2020, 09:17 PM
timatoe
timatoe's Avatar
I'd do like mentioned above and have someone turn the wheel while looking at what's happening. Are the tie rod ends rolling before things move? If so the link above may work. If nothing is moving but the column, then the box,,,, it's likely the box.
timatoe is offline
