YJ steering box 90 vs 95 - JeepForum.com
 3Likes
  • 2 Post By Luuca
  • 1 Post By jbolty
post #1 of 5 Old 05-21-2019, 07:30 PM Thread Starter
billybob535
I am going to swap the entire powertrain from a 95 YJ into a 90 YJ. Will the 95 power steering lines be the correct style/size connector to connect to the 90 steering box? Thanks
billybob535 is offline
post #2 of 5 Old 05-24-2019, 01:48 PM
NHfireLJ
NHfireLJ's Avatar
depends on if the 90 was power steering... if both power steering then yes....
AUDREY...95 YJ UNLIMITED
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #3 of 5 Old 05-24-2019, 04:35 PM Thread Starter
billybob535
So the 95 lines will fit the 90 power steering box without modification?
post #4 of 5 Old 05-24-2019, 08:14 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
a simple way to do this type of research yourself is to create an account with Autozone online. Add in a 1990 Jeep YJ 4.0 as one of your vehicles, then add another vehicle a 1995 Jeep YJ 4.0.
Using the 1990 vehicle, search for the power steering lines. The site will provide you a part number for those lines and a price. Without leaving that page, change the vehicle from the 1990 YJ to the 1995 YJ. Once the site updates, if the part for the 1990 will not fit the 1995, the site will plaster a warning that the part does not fit. Or you can simply write down the part number and search for the 1995 same part and see if the parts are the same part number. Often, they are the same.
I will say that if one of the vehicles is a 2.5L (4 banger) and one is a 4.0 (6 cylinder) the lines will not work.
timatoe and NHfireLJ like this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #5 of 5 Old 05-24-2019, 08:50 PM
jbolty
jbolty's Avatar
even easier than that, go to https://www.oreillyauto.com/ find the part then click on compatibility and it will show everything that part fits. Also great for finding junk yard donors for certain parts.
(random screen shot, not the steering box)
timatoe likes this.
jbolty is offline
question about airbag light catfishman XJ Cherokee Technical Forum 10 11-11-2018 03:52 PM
Sticky steering box Snowturtle Jeep CJ Forum 2 06-21-2018 05:50 PM
Steering box spline counts jeepcj785 Jeep CJ Forum 0 04-24-2018 07:45 PM
Help needed - steering box if off by 45 degrees after box swap and alignment Ewout_vB WJ Grand Cherokee Forum 11 03-04-2018 03:30 PM
Hard Steering after reman steering gear box install FLWK2 ZJ Grand Cherokee Forum 2 02-22-2018 04:15 PM
