YJ sport bar types - JeepForum.com
 6Likes
  • 2 Post By fishadventure
  • 2 Post By bruinjeeper
  • 1 Post By bgredjeep
  • 1 Post By Sussum
post #1 of 15 Old 11-13-2019, 07:36 AM Thread Starter
Sussum
Sussum's Avatar
YJ sport bar types
I have a 1990 YJ with a family bar, and this winter I plan to replace it with a sport bar, since I do not use a back seat, and I prefer the way they look. My family bar has supports that come forward and connect to the windshield frame. For the sport bar, I can choose between one with those supports, or without them, like CJs have. Is a certain type better, or safer? Will the windshield on a YJ be supposed without the roll bat supports?
Sussum is offline
post #2 of 15 Old 11-13-2019, 09:16 AM
DRLExpress
DRLExpress's Avatar
Will be watching this thread as I want to do the same thing for the same reason. Just looks more like a jeep is supposed to.
I have not started checking junkyards yet. Do CJ7 bars bolt into YJ's.
Doug
DRLExpress is offline
post #3 of 15 Old 11-13-2019, 09:27 AM
cpia84
cpia84's Avatar
Where are you located? I have the sport bar like in the first picture and i want to swap in a family bar since i do use my back seat and i want to have the longer soft top as well to cover the back.
I believe you have the windshield self supporting. I plan on doing a roll cage and tying it into the frame so i think for that I will need supports to the windshield.
I have seen them with and without so it should be possible. It might just depend on if you keep a top on it or not but im not 100 sure.
cpia84 is offline
post #4 of 15 Old 11-13-2019, 09:40 AM
fishadventure
fishadventure's Avatar
@cpia84 your profile doesn’t say where you are either...
BTW you def want the windshield supports imho....
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #5 of 15 Old 11-13-2019, 11:47 AM
cpia84
cpia84's Avatar
Originally Posted by fishadventure View Post
@cpia84 your profile doesnít say where you are either...
Oh i thought it at least said what town im in. I am in North Carolina.
I will definitely make sure i have windshield supports. I agree they should be used.
cpia84 is offline
post #6 of 15 Old 11-13-2019, 12:57 PM
KARamsay
I have a 1989 -
I put them on with the hard top (Makes things a bit stiffer) and take them off in the summer.
I have the CJ thumb knobs
bars off - nubs on - I take the nubs off too when I take the hard top off
KARamsay is offline
post #7 of 15 Old 11-13-2019, 01:03 PM
dsaylor
dsaylor's Avatar
The PO removed the spreader bars on mine and I like the look. Iíve never had an issue, but Iím careful. If you pull on the windshield frame, it is possible to crack the glass. I imagine the spreader bars might prevent this to some degree.
Sent from my iPad using Tapatalk Pro
88 yj 4.2 Weber Carb
Mostly Stock
dsaylor is offline
post #8 of 15 Old 11-13-2019, 03:48 PM
NHfireLJ
NHfireLJ's Avatar
To the OP, if you are ever in an accident, I would want the spreader bars to the windshield... off or on road...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #9 of 15 Old 11-13-2019, 07:07 PM
Boojo35
1987 YJ Wrangler
I have a 94 with the family bar and a 87 with the sport bar. Both need and have the spreader bars to the windshield frame. I would never run without them. The windshield frame on its own will never support any type of rollover or upwards hit of anything on the vehicle without the spreader bars. It would not even keep a high deer hit from wrecking your life.
I have done some pretty extensive messing around with my Jeeps. The tubs on them are downright flimsy and flex all over the place when off the vehicle. Even on the vehicle. The so called "roll cage" is important to help your door openings maintain shape and your doors open and close correctly, help your top fit, etc. Still overall, a very flimsy vehicle. Very poor bracing and support.
The so called "roll cage" is nothing of the sort BTW. It is by no means the structural strength needed to be a roll bar or roll cage. It is nothing more than a piece that made these pass marginally safe for road use. They are not for sure safe for hardcore offroad use if the extreme situation happens.
If anything. It needs to be beefed up. Not eliminated,
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #10 of 15 Old 11-13-2019, 09:13 PM
fishadventure
Now he knows the truth!
“The spreader bars don’t really do anything” is the mantra of the ill-advised.
Boojo35 and NHfireLJ like this.
post #11 of 15 Old 11-14-2019, 08:12 AM
NHfireLJ
NHfireLJ's Avatar
ďThe spreader bars donít really do anythingĒ is the mantra of the ill-advised.
To the OP...
Seen plenty of yj, tj rollovers (I'm in the fire service) and although not a full cage, the windshield DEFINITELY provide some protection with the spreader bars.... Much more that without...
SOLD
style intake
NHfireLJ is offline
post #12 of 15 Old 11-14-2019, 10:30 AM
bruinjeeper
bruinjeeper's Avatar
Waiting for @bgredjeep to chime in here and ask, "What's a windshield?" Lol
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #13 of 15 Old 11-14-2019, 05:35 PM
Boojo35
1987 YJ Wrangler
post #14 of 15 Old 11-15-2019, 06:38 AM
bgredjeep
bgredjeep's Avatar
1987 YJ Wrangler
Hey now, just because I wear my "windshield" on my face these days.. lol
I'm with the spreader crowd. It isn't needed to support the windshield for normal use, but adds a lot of structure in the event of a crash. Beyond that, I'd prefer at least a basic front cage added for anything used offroad at all.
When I was still running a windshield and the Jeep had a cage, the only thing I had holding the windshield up was a lashing strap so I could pull the whole thing off in about 2 mins.
NHfireLJ likes this.
bgredjeep is offline
post #15 of 15 Old 11-16-2019, 08:48 AM Thread Starter
Sussum
Sussum's Avatar
Thanks everyone, I will be getting the one with the supports. I'm in central ohio, and I plan on keeping the family bar around in case I decide to switch back at any point.
Sussum is offline
