YJ spitting and sputtering randomly...HELP! - Page 2 - JeepForum.com
post #16 of 21 Old 06-28-2018, 12:37 PM
bharris68
Gravel Truck Pilot
Good deal!
remember - it's not the engine IS running too cool, it's the sensor sending a signal that the engine "APPEARS" to be too cool - big difference. Sensors are the menu, not the meal
I've not had issues with my temp sensors before so others may have a better idea exactly which ones are going to be sending that temp data to the computer. You may also be able to intercept the signal via the diagnostic ports next to the battery.
bharris68 is offline
post #17 of 21 Old 06-28-2018, 03:04 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Originally Posted by nolanhickson View Post
Success!!! Got the check engine light replaced (thanks to that useless seatbelt indicator light giving up its bulb) and got some codes.
It threw these codes at me:
21: oxygen sensor/circuit
24: throttle position sensor/circuit
17: engine running too cool
The 21 and 24 codes are child's play, I've replaced those parts before. Will replace them again, with hopefully some higher quality components.
But the 17 code....not sure on that one. The Jeep runs at around 200 or so degrees, why is that too cool?
I have a '95 FSM, powertrain manual, and parts catalog. Send me a PM with the ones you want, and I'll PM the links to you. They will really help you figure it out.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #18 of 21 Old 06-28-2018, 03:22 PM
Waternut
Waternut's Avatar
The temp sensor at the front of the engine is one that feeds the PCM. The one at the back of the engine feeds the temp gauge. That fix is even cheaper and easier than the other two.
Waternut is offline
post #19 of 21 Old 06-28-2018, 05:53 PM
shaggyjim
NARF!
shaggyjim's Avatar
If you have a multimeter you should do some testing of your sensors before you replace them. One other thing to think about is going back to sensors from a Jeep dealer. They are better quality then the parts store parts.
Jim...
SGT USMC.
......YJOTM June 18......
shaggyjim is offline
post #20 of 21 Old 07-01-2018, 02:23 PM Thread Starter
nolanhickson
I replaced the O2 sensor and the TPS, both of which seemed to help the Jeep run better overall. But, the issue persists (although not as bad!)
I guess the next step is to pull spark plugs, to see if I've got a bad injector?
nolanhickson is offline
post #21 of 21 Old 07-02-2018, 09:56 PM
Mechman71
When you pull your plugs, check also to see if one of the electrodes is cleaner than the others, and possibly lightly tinted green like your coolant. Given the progressive nature of this problem, my suspicion would be a head gasket failure that is going from minor to... well, not so minor.
'89 YJ "Night Eagle" 4.2 5spd, Spinnaker blue/grey, hard top and doors, mostly stock and RUST FREE!!
Mechman71 is offline
engine , trouble , wrangler , YJ
