YJ PCM question - JeepForum.com
post #1 of 9 Old 03-17-2020, 07:59 PM Thread Starter
jeepin4
YJ PCM question
Hi all. I have a question that is a little complicated. I have a 91 YJ that originally came with a 2.5L. When I blew that motor I swapped in a 97 XJ 4.0 motor with the harness, PCM, and remaining parts from a 93 YJ. I am starting to have issues with the PCM and need to swap it for another. So, my question is what years 4.0L PCM can I swap in? Obviously another 93 would work, but any other years?
jeepin4 is offline
post #2 of 9 Old 03-17-2020, 08:23 PM
ThomasYJ
ThomasYJ's Avatar
hell you can have my PCM. 93 4.0 manual trans.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is online now
post #3 of 9 Old 03-17-2020, 08:37 PM
ThomasYJ
ThomasYJ's Avatar
but maybe more appropriately, what PCM issues are you having?
The Toy:93 YJ
The DD:00 F250 7.3
Build:
post #4 of 9 Old 03-17-2020, 08:51 PM Thread Starter
jeepin4
I’m having a starting issue. PCM is not powering up the fuel pump. Turn ignition in the on position and no lights on dash, and no fuel pump prime. Engage the starter and it just cranks and cranks. From everything I’ve found online, something in the PCM goes bad and creates all the symptoms of what’s happening.
I am looking for a 4.0 manual PCM. Where are you located?
jeepin4 is offline
post #5 of 9 Old 03-17-2020, 08:55 PM Thread Starter
jeepin4
jeepin4 is offline
post #6 of 9 Old 03-17-2020, 08:57 PM
ThomasYJ
ThomasYJ's Avatar
Originally Posted by jeepin4 View Post
Iím having a starting issue. PCM is not powering up the fuel pump. Turn ignition in the on position and no lights on dash, and no fuel pump prime. Engage the starter and it just cranks and cranks. From everything Iíve found online, something in the PCM goes bad and creates all the symptoms of whatís happening.
I'm in Washington. If you want it, whatever the shipping cost is and it's yours, I'm doin a V8 swap and have no use for it. Got a bunch of other 4.0 stuff that needs a good home too Airaid intake, 99 manifold, silicone rad hoses etc etc
The Toy:93 YJ
The DD:00 F250 7.3
Build:
post #7 of 9 Old 03-17-2020, 09:07 PM Thread Starter
jeepin4
That would be great. I appreciate that. I’ll PM you and we can work out the details. Thanks!
jeepin4 is offline
post #8 of 9 Old 03-18-2020, 10:54 AM
Siva283
Siva283's Avatar
I have a 95 4.0 computer that would work if you are OBD1. If you used the newer 97 obd2 computer you will need one of those. The harness is way different between obd1 and obd2
Ask me how I know...
Siva283 is offline
post #9 of 9 Old 03-18-2020, 03:18 PM
NHfireLJ
NHfireLJ's Avatar
If you're getting one for free great, if not then fix yours.
See here... https://www.jeepforum.com/forum/f12/...rs-ecu-492597/
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
