YJ instrument cluster - JeepForum.com
 4Likes
post #1 of 24 Old 12-23-2019, 09:34 AM Thread Starter
vet101abn
I have a 1987 YJ that I am trying to install aftermarket gauges. I was hoping that someone had the wiring pinouts for the instrument cluster connector? My connector is a 12 pin with #8, #9 and #11 not used. Any help would be GREATLY appreciated.
vet101abn is offline
post #2 of 24 Old 12-24-2019, 06:44 AM
fishadventure
fishadventure's Avatar
Welcome to the forum. Post #1! You’ve joined the most helpful and thorough place for YJs on the interestingnet<img src="https://www.jeepforum.com/ubb/smile.gif" border="0" alt="" title="Smilie" class="inlineimg" />
87-95 ALL use “the same connector” but the assignments vary early years to late years.
I don’t have the colors at ready access, but others have posted this several times in recent months and I have searched using yahoo and found the wire/function chart several times.
The best way to search the forum on this:
Type the next line exactly including quotes into a search bar in google, webcrawler, yahoo or whatever
“Jeepforum.com/forum/f12” gauge wire color diagram
There’s a bunch of stuff there
Here’s one from the Grand Resort and Casino, a famous jeep technical reference clearing house: https://www.jeepforum.com/forum/f12/...topics/4275745
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #3 of 24 Old 12-24-2019, 10:57 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Maybe this info can help you?
https://drive.google.com/file/d/1KMM...pctHizdre/view
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Found out Grandpa is addicted to Viagra. No one is taking it harder than Grandma...
laybackman is offline
post #4 of 24 Old 12-24-2019, 04:58 PM
timatoe
timatoe's Avatar
I was gonna look and see if I still had that pic somewhere.
timatoe is offline
post #5 of 24 Old 12-25-2019, 07:41 AM
jay-h
I've had to mess around with that cluster a few times. Fortunately the traces are easy to follow in the printed circuit board. I'd get a pencil and paper and mark them down.
If you're putting in new aftermarket gages, you're probably using new sensors as well. Might be a good time to run new wires.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #6 of 24 Old 12-25-2019, 01:42 PM
fishadventure
This will make “rewiring” that easier as well as serviceable if you’re going to hardwire it:
12 terminal weathertite connector https://www.amazon.com/dp/B01CRV0RUM..._3J8aEbPZYWKGA
post #7 of 24 Old 12-25-2019, 05:49 PM
timatoe
timatoe's Avatar
Yep, that's what I did as well. Anytime I'm wiring in something that may need to be removed .... ever..... I use pin connectors. Just makes life so much easier, especially since I already have the proper crimpers etc.
timatoe is offline
post #8 of 24 Old 12-25-2019, 05:56 PM
fishadventure
I forgot- you do need actual pattern crimpers (can’t remember the style name; I have them) and not useless hardware store wannabe crimpers
:this might be them: IWISS Open Barrel Terminal Crimper Plier Tool for Molex Style DELPHI AMP TYCO Terminals Crimper Open Barrel 24-14 AWG https://www.amazon.com/dp/B07476C1LD..._TtabEb3YVXGZP
post #9 of 24 Old 12-25-2019, 06:55 PM
timatoe
timatoe's Avatar
Yep those are the ones..... I had an old set where you had to do each of the two crimps individually. I bought a set of the IWISS ones with interchangable heads on amazon for less than $30, they're ratcheting so you get good solid crimps and it does both at once, I love them.
timatoe is offline
post #10 of 24 Old 12-28-2019, 06:52 AM
fishadventure
Huh. I think I paid more than that and mine require three ‘actions’ - I’ll need to look those up
post #11 of 24 Old 12-28-2019, 04:48 PM
timatoe
timatoe's Avatar
These....
IWISS Crimping Tool Kits with Wire Stripper and Cable Cutters Suitable for Non-Insulated & Insulated Cable End-Sleeves Terminals or Ferrules with 5 Changeable Die Sets in Oxford Bag
by iwiss
https://www.amazon.com/dp/B00Y7M7SG6..._XL-bEbY862ZCX
timatoe is offline
post #12 of 24 Old 06-17-2021, 07:46 PM
themarkwilkins
This is an amazing product! I think that this is interesting but as far as I am concerned, Amazon doesn't accept any cryptocurrency as a form of payment. Still, I think some people tend to do it. Might as well learn how they do that.
themarkwilkins is offline
post #13 of 24 Old 06-18-2021, 06:11 PM
gehlsurf
gehlsurf's Avatar
If you dont mind me asking, sorry I can't help ya, but what aftermarket gauges are you gonna use? Do they fit in where the stock ones do?
gehlsurf is offline
post #14 of 24 Old 06-18-2021, 09:29 PM
timatoe
timatoe's Avatar
I don't think the OP is gonna get back to you since he's only had 2 posts since '19. But maybe...
I used Autometer Phantom gauges, you may be able to get them to fit the stock bezel but I used this instead... https://www.quadratec.com/products/12500_220.htm
timatoe is offline
post #15 of 24 Old 06-18-2021, 11:03 PM
SevenSlotAddict
Heres a new link to the crimpers mentioned above.
https://www.amazon.com/dp/B08DRCRRCQ...xpY2s9dHJ1ZQ==
SevenSlotAddict is offline
