Yj half top help - JeepForum.com
post #1 of 12 Old 03-28-2017, 09:40 PM Thread Starter
Bubseth
Yj half top help
Hey guys summer is coming and I'm ready to ditch my hardtop and I was wondering what you guys think about the smittybuilt cover kit it has the bikini top wind breaker and tonno cover. I just wanna know if anyone knows how this fits I have a 1990 yj. Also how is it with rain? Is a little water getting in or is gonna soak everything. I can put a full soft top on but I like the looks of this and I plan on taking my steel doors of and running half doors with soft uppers. But if I pretty much can't drive it in the rain or even have it outside while it's raining I don't think it be worth it. I'll appreciate anyone's opinions on it
Bubseth is offline
post #2 of 12 Old 03-28-2017, 09:42 PM Thread Starter
Bubseth
Here is what it looks like
Bubseth is offline
post #3 of 12 Old 03-28-2017, 09:48 PM
93YJfalcon
I really like the looks of mine, BUT I hardly ever use it because of the huge gap between the side windows and the roll bar, it really limits what you can put in the back, and it seems even less secure than a soft top (if that's even possible). You will get wetter than you think, lol.
That being said though, I'd take it over a hard top.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #4 of 12 Old 03-29-2017, 03:35 AM Thread Starter
Bubseth
Does the tonno cover let it a lot of water
Bubseth is offline
post #5 of 12 Old 03-29-2017, 06:10 AM
EABiker
The tonneau cover keeps the rear section dry, and everything else works if the rain is light. Heavy rain and wind will get you wet though, for sure! You will want to make a prop for the bikini top, as the rain tends to pool on it when you are not moving. I made a bow prop out of pvc tubing that fits between the roll bars. I never use my wind breaker, and as a matter of fact, I keep the bikini rolled up under the seat and only put it on if I get caught in the rain.
EABiker is offline
post #6 of 12 Old 03-29-2017, 07:39 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
I use a combination of a safari top and trail cover during the summer. The safari top give you a little more cover than a bikini top and the trail cover keeps the inside dry when it's parked and raining hard. You will get wet when driving. The wind from driving will push the rain forward.
My Jeep's not my DD so I don't need to drive it if the weather is bad.
-John-
johnboy68 is offline
post #7 of 12 Old 03-29-2017, 12:01 PM Thread Starter
Bubseth
Has anyone seen the rampage half top? It looks like it's sealed so water can't get in it's not as nice looking but it looks like it would keep the inside dry
Bubseth is offline
post #8 of 12 Old 04-01-2017, 12:21 PM
timatoe
timatoe's Avatar
You may want to contact Rampage and see if the set up you have will work with their top. I was about to pull the trigger on one of those but called to double check because I found conflicting info on the net (including pics on their site) about whether it would work with rounded upper doors (I have full hard doors).
I like the Bestop half cab too and thought about that as well and just modifying the rear bars to the family style to fit the top, but even though it uses identical parts to my Sunrider top, except two pieces I can buy individually, they won't sell just the skin and I'm not dropping $700 on it.
timatoe is offline
post #9 of 12 Old 04-01-2017, 01:16 PM
StanF
Mine isn't a DD, and I run like this almost all year long. Doors come off in the summer. Trail top stays in the Jeep in case I misjudge the weather, but it is rarely used.
I have a full soft top, but rarely put it on.
The gaps at the top of the window will let in a lot of rain. It's not so bad when you are driving, as the rain seems to just blow past. But when sitting still, you'll want a trail top or something else.
I've read about someone fabbing in the TJ door surrounds to seal things up. I thought about doing something like that, but moved on to other projects instead.
StanF is offline
post #10 of 12 Old 04-01-2017, 05:32 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
That three piece combo is crap for weather. I had it for a month, used twice. Since I always have a tonneau anyway, and two piece soft doors in the back for extended outings, I ended up making my own half soft top because no one had anything decent (and still doesn't, in my opinion).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #11 of 12 Old 04-01-2017, 05:36 PM
Chrisnvegas
Chrisnvegas's Avatar
I like that top you made. Post a refresher pic please.
Societies that are truly free can survive only if an open debate and an uncensored exchange of ideas can take place
Chrisnvegas is offline
post #12 of 12 Old 04-01-2017, 07:18 PM
JeeperDon
JeeperDon's Avatar
Thanks Chris. The tonneau and doors are Bestop.
Web Admin for
