YJ evaporator core replacement steps - JeepForum.com
post #1 of 9 Old 07-20-2019, 02:22 PM Thread Starter
Fishstic
Fishstic's Avatar
Got a leak that I think is coming from the Evap core, also planning on replacing the heater core (not now though) what're the steps/can I get a write up am I going to have to remove the dash? I'm ready to do it (unwillingly)
For some context, every now and then water leaks from the metal pipe that comes out of the fire wall on the passenger side, gets all over passengers feet. Thinking it's a clog in the evaporator core drain, or maybe it's icing really bad.
Sent from my ONEPLUS A6013 using Tapatalk
Fishstic is offline
post #2 of 9 Old 07-20-2019, 02:45 PM Thread Starter
Fishstic
Fishstic's Avatar
Just read the service manual, apparently if I have a condensation leak inside the cabin I should flush/clean out it's drain hose, I'm guessing the one connected to the drier? Unless it uses the same tubing as the heater core? Anyone know how to flush the drain?
Fishstic is offline
post #3 of 9 Old 07-20-2019, 02:46 PM Thread Starter
Fishstic
Fishstic's Avatar
Leave this here if anyone needs it
Fishstic is offline
post #4 of 9 Old 07-20-2019, 06:58 PM
zrickety
zrickety's Avatar
To the best of my knowledge, you'll have to remove the unit from under the dash. Not the dash itself. You might be able to do it without removing the hoses, but getting inside the evaporator is tedious. Mine is completely out of the Jeep right now for a new switch.
1988 Jeep Wrangler Laredo
zrickety is offline
post #5 of 9 Old 07-21-2019, 03:59 PM
Boojo35
Here are some pics that might help you.
This is what you would see on the top and backside of the AC unit on the drivers side.
This would be the passenger side
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 9 Old 07-21-2019, 04:10 PM
Boojo35
A picture of the drain that should face the fire wall and be near the center of the vehicle.
In this picture you can see the distance that the lines travel outside of the case to the firewall. The fire wall mounting flange is to the lower left of the picture. The lines outside the case can sweat and drip also. Even the Jeep factory air is a standalone add on system. This is why it is designed like this but the exposed lines between the box and firewall and potential sweating of them is a downside.
The good news is that it really makes adding an AC system onto a YJ possible.
Boojo35 is offline
post #7 of 9 Old 07-21-2019, 06:21 PM Thread Starter
Fishstic
Fishstic's Avatar
Attachment 3844775
Attachment 3844777
Used the 2nd picture to find out where the leak was coming from, went for a drive for 2 hours and saw the water coming out, I'm assuming this is connected to the drier? Maybe if I use some adhesive it'll fix it, but if it is a clog then It wouldn't be sorta pointless.
Fishstic is offline
post #8 of 9 Old 07-21-2019, 06:36 PM
Boojo35
Attachment 3844775
Really look at this pic here. If your AC is on, water needs to be able to exit this drain freely. So, if you disconnect it water will flow out pretty steady on a humid day, There is a rubber hose that should be connected to this drain that makes this water exit the interior of the vehicle. If this drain is plugged, water will build up in the housing and drip out places like shown in your picture. I guess to this point it has been unclear to you. check the drain.
Boojo35 is offline
post #9 of 9 Old 07-21-2019, 07:54 PM
Louie4
Injanir
Louie4's Avatar
I say it's a clogged drain line. Or you could of had my problem and had the hose kinked by the heater diverter. I found out by running the AC and taking a right turn and having water pour out of the small vent on the left.
Not sure if I will help but here is a thread I did on my AC refurbish.
https://www.jeepforum.com/forum/f12/...rbish-1010356/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
