YJ to CJ Dash Conversion No Panel Lights - JeepForum.com
 1Likes
  • 1 Post By 1project2many
post #1 of 9 Old 05-15-2019, 08:43 PM Thread Starter
disarm6565
Ok, I've researched this for years, I actually did my build like a year ago. One of the last things I can't figure out is how to get my gauge lights working. All of the rest of my lights work, but no indicators and no panel lights. I suspect this has to do with the lack of a dimmer switch in the wiring. Does anyone have any insight to this? My high beams are still activated through the column, there is no floor switch which is called a "dimmer switch" on the CJ7 models. I have the left over Yellow, Tan, Blk/Yellow/ and Black just dangling from the swap. Any help is appreciated.
1993 4.0 AX-15
disarm6565 is offline
post #2 of 9 Old 05-16-2019, 02:54 AM
1project2many
The Dimmer switch was moved from the floor to the column in the '70s. That's what you currently use to switch from high to low beam.
But what are you using for a headlight switch? When you installed the CJ dash, did you build a harness from scratch, modify the YJ harness, or use one made for the swap? Is the CJ dash a real, steel CJ dash or is it a fiberglass kit?
Que89YJ likes this.
1project2many is offline
post #3 of 9 Old 05-16-2019, 07:59 AM Thread Starter
disarm6565
It's a real CJ dash and I modified my YJ harness. I bought the 5 pin CJ headlight switch and modified the YJ harness to work with it. The only "leftover" wires were the ones going to the "dimmer" switch on the YJ which is also affected by the radio illumination. I know it's the orange wire that illuminates the gauges but for whatever reason it doesn't.
I guess my real question is do I need to jump something off the low beam or park wire? Or is that going to blow a fuse.
1993 4.0 AX-15
post #4 of 9 Old 05-16-2019, 09:17 AM
Que89YJ
Why did you use the CJ light switch? All the illuminations are linked together on the stock YJ. The gauges you are using are aftermarket so I dont know what you have going as far as them. They should all be hooked together to a common Illumination feed. That feed should be at the dimmer switch. As far as indicators go again what are you using for the indicators? They need power and ground. The feeds need to be hooked to each and a ground supplied to the other side to light the indicator. Did you wire ground?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 9 Old 05-16-2019, 10:14 AM
Waternut
Waternut's Avatar
There are many ways to make this work. The YJ wiring harness may not have a direct replacement for the CJ switch you're talking about but it has a wire that illuminates all gauges when the headlights come on. If you can't get that to work or can't find the wire, just tie a wire into the headlight switch to power all the dash lights. It wouldn't blow a fuse since everything should be 12 volts and the gauges shouldn't be pulling a lot of power but a relay would be the smart move. Wouldn't hurt to run a fuse either. I don't necessarily condone my methods but I run my LED headlights and all of my gauge lights off a 20amp switch without a relay because I went with a V8 and ripped pretty much all of the old YJ wiring harness out.
Waternut is offline
post #6 of 9 Old 05-16-2019, 11:39 AM Thread Starter
disarm6565
back in my YJ dash days I used to jump them off the blue/white ignition feed. But I feel like that used to pop my ACC fuse occasionally.
1993 4.0 AX-15
post #7 of 9 Old 05-16-2019, 02:07 PM
Waternut
Waternut's Avatar
I actually run the vast majority of my interior components off the ACC plug in the fuse block. Granted it's pretty spartan in my jeep but I run the radio and all gauges off of that. I may even run the ECU off of that but I don't remember. I just have a large bus bar that I tie a bunch of stuff into. Some are always hot, some are ignition, and some are easy access to grounds.
Waternut is offline
post #8 of 9 Old 05-16-2019, 02:18 PM Thread Starter
disarm6565
I figured it out. Blk/Yellow wires comes off a splice from the headlight switch. That has to be spliced to Orange off the fuse box on the inside. I even spliced some extra orange an orange wires back there just to be on the safe side.
1993 4.0 AX-15
post #9 of 9 Old 05-16-2019, 02:26 PM
1project2many
The black/yellow should have power when the park lights are on. That powers the dash lights in the YJ. Power goes through the panel brightness control (the dial that makes the dash lights brighter) then is routed through the tan wire to fuse 10 of the fuse box. From fuse ten power is carried back to the lights in the orange wire.
The CJ switch powers a red wire at terminal 66. The red wire carries power to the accy lamps fuse then up to the dash lights. The power at 66 appears to go through the brightness control.
So you should have two terminals on your CJ switch connected to the "dial" that adjusts dash light brightness. If you can find terminal 66 which is connected to the dial that makes the lights brighter, connect the tan wire to it and the factory lights should work. If you don't care about the brightness dial just connect black/yellow to the tan.
Edit:
Proving once again that Jeep published wiring diagrams then did whatever they wanted when it came time to build the vehicle. lol.
1990 XJ Electrical Gremlins-No dash lights, no tail lights lrsmithwhaley XJ Cherokee Technical Forum 5 03-10-2019 08:35 AM
Dash Lights Flickering TN98TJ TJ Wrangler Technical Forum 4 01-25-2019 11:08 AM
CJ7 Dash Swap Headlight Switch Conversion disarm6565 YJ Wrangler Technical Forum 2 10-11-2018 10:11 AM
Dash lights dim when blinker turned on 2011 Liberty kormath Audio, CB & Ham Radios, GPS, & Electrical 2 07-03-2018 08:41 AM
01 Wrangler electrical issue (running lights & dash lights) FixJade TJ Wrangler Technical Forum 25 06-23-2018 07:25 PM
