YJ check engine light operation when key turned on - JeepForum.com
post #1 of 2 Old 03-11-2019, 05:14 PM Thread Starter
Boojo35
This was brought up on a thread before. The YJ Check engine light going off after a couple of seconds when the key is turned on. The industry normal has been to leave the check engine light on until a certain amount of ignition reference or pulses has been received by the puter and then turn it off. In other words, in most vehicles it shuts off when the engine starts or in some cases cranks crazy fast.
I looked high and low to prove or disprove this theory. Why the hell would Jeep be out of the normal from what seemingly everybody else does? It ends up that this is a JEEP thing. I randomly found it while searching for info for the guy that "pull starts" his YJ.
The known capacitor problems with ECMS and other issues made me question if this is correct.
Note that the CHECK ENGINE lamp will illuminate
initially for approximately two seconds each
time the ignition key is turned to the ON position.
This is done for a bulb test.
Straight from the Jeep manual...... Good Lord.... I can finally sleep again... LOL>
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #2 of 2 Old 03-12-2019, 07:02 PM
bruinjeeper
bruinjeeper's Avatar
hahahahaha.
Good work, Columbo!
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 447 02-02-2019 10:42 PM
No check engine light, no fuel pump, no start? tropicalYJ YJ Wrangler Technical Forum 7 11-14-2018 07:14 PM
check engine light always on even when off johnyj YJ Wrangler Technical Forum 3 08-15-2018 04:40 PM
Check engine light... Sondra3 WK2 Grand Cherokee Forum 16 08-13-2018 08:18 AM
Check Engine light 1995 YJ 2.5 manual W/AC Bareboat YJ Wrangler Technical Forum 2 11-25-2017 04:42 PM
