YJ Chat and non tech - Page 1310 - JeepForum.com
 10781Likes
post #19636 of 28034 Old 09-10-2016, 12:06 PM
bgredjeep
bgredjeep's Avatar
1987 YJ Wrangler
That's awesome man. Got a link to a digital article of that?
Here's the link for the online version of the magazine. I don't have a digital version of my article.
http://www.magzter.com/US/4LOW-Offro...ne/Automotive/
bgredjeep is offline
post #19637 of 28034 Old 09-10-2016, 12:39 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Real Alaskan YJ. Spotted at the parking lot of Mendenhall Glacier Lake.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #19638 of 28034 Old 09-10-2016, 05:51 PM
Cmanjr
1987 YJ Wrangler
how was the thing for rust? lol
Red 87 YJ - 4.0L - AX15 - NP231 - D30/35
Cmanjr is offline
post #19639 of 28034 Old 09-10-2016, 07:07 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
After a Google search I found the solution to my gauge problem in the MJ. One speedometer works, and that's with the idiot lights. The second one doesn't work right and that's with the gauges.
So, take the clusters apart and switch the working speedometer to the cluster with the gauges. Hook it up. Oil pressure and temp gauge tap out. Put the volt meter works. Cool.
Go get the new sensors, for a later model MJ and bam. Oil pressure aaand temp gauge. Fuel gauge is either broken or grounded out somewhere. Not sure how to fix that one.
Dirty, but works.
Chrisnvegas and cKruzer like this.
Michaelgoesrawr is offline
post #19640 of 28034 Old 09-10-2016, 08:00 PM
Chrisnvegas
Chrisnvegas's Avatar
They weren't fooling around when they designed that fuel gauge.
It's HUGE!
Good oil pressure.
cKruzer likes this.
A Law repugnant to the Constitution is void. Marbury vs. Madison 1803 I'm talking to you, Virginia...
Chrisnvegas is offline
post #19641 of 28034 Old 09-10-2016, 09:37 PM
cKruzer
cKruzer's Avatar
1987 YJ Wrangler
Originally Posted by xrunndonex View Post
5" 1/2inch titanium 85 degree bend 45degree chamfer
Trying to get all the measurements so i can give an accurate drawing to the machinist friend. Do you know the other measurements?
Rust really isnt a huge problem up there, because they dont use salt, etc. They put down gravel.
1987 YJ - Aka; SpeedBump.
Target: 5.3L; 4L60; Atlas; D44/D60; 4.88s; 36s
הָיָה הָיָה הָיָה
YJOTM AUG '17
cKruzer is offline
post #19642 of 28034 Old 09-10-2016, 09:44 PM
Michaelgoesrawr
It's HUGE!
Good oil pressure.
I know. Both of them are like that. I think the later models move it and there is a tach there. Not sure though.
These gauges are weird. The oil pressure gauge will stay where it's at when it shuts off. Same with the temp gauge. The oil pressure resets when you start it. I'm assuming the temp gauge will do the same but it was at temp every time I started it tonight. Ideally I'd like autometer but whatever.
post #19643 of 28034 Old 09-10-2016, 10:04 PM
Michaelgoesrawr
Uh oh. Sledgehammer isn't going to be as hard anymore.
https://m.facebook.com/story.php?sto...d=262003834371
post #19644 of 28034 Old 09-10-2016, 10:05 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Alice is running like a champ.
Exactly 105 miles from Provo Utah, the CEL comes on and from the random stutters, I know it's the TPS. The same code and symptoms I had two weeks ago when I replaced it with a new one.
Nearest autozone is 105 miles away in Provo. F it. Drove it there with the CEL on. Stop and get codes. Yep. TPS. Warranty the one on the car and replace it in the parking lot.
Start it up and all of the sudden, front axle is locked. Like I'm in 4hi. Shift it into 4 hi and back into 2hi while moving and axle still locked. Wtf?
Get under the Jeep and readjust the shift linkage. It's correct. *scratches head*
Front axle is D35 with Ausssie locker and factory CAD.
Need to confirm we are in 2hi. Buy a floor Jack in a case. Figure the kid can keep it. Jack up the front end and YEP. We are in 2Hi.
So CAD is not disengaging. Hit it with a hammer a few times and drive straight trying to unlock it. No dice.
F it. It'll be fine. Get on the freeway and doing 70 the 4WD light comes on and scares the crap outta me
Pull off to a parking lot. Remove the vacuum connector at the CAD and drive around. Still locked. Get back under there to re attach it and I remember that I had this issue before when I swapped in the axles initially. I had the connector on backward. Flipped it around and boom. Unlocked.
Wasted about an hour on those two things. Other than those everything is going well. Just passed Salt Lake City about 3 hours to go into Idaho Falls.
I can't help but think these would have been found if I would have had time for a month long shake down run. Oh well.
The Alaskan YJ was surprisingly in great shape. Rust on the springs and steering but no body rot. Good Jeep IMO.
Chrisnvegas likes this.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #19645 of 28034 Old 09-10-2016, 10:08 PM
Michaelgoesrawr
Damn. Can't trust that VatoZone crap.
cKruzer likes this.
post #19646 of 28034 Old 09-10-2016, 10:20 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Hahah
Here's my extended family in an ice cave under the Mendenhall Glacier in Alaska. We rowed a native canoe across a 3 mile lake the long way and trekked across the glacier to the cave.
The wife and I on the glacier. We wore metal spikes. Very cool day.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #19647 of 28034 Old 09-10-2016, 10:25 PM
cKruzer
cKruzer's Avatar
1987 YJ Wrangler
It's beautiful. I'm up there every winter and spring. Very enjoyable
הָיָה הָיָה הָיָה
YJOTM AUG '17
cKruzer is offline
post #19648 of 28034 Old 09-10-2016, 11:58 PM
Chrisnvegas
I think she's doing well.
You did a **** ton of work and have very few bugs to work out.
post #19649 of 28034 Old 09-11-2016, 12:51 AM
Michaelgoesrawr
That picture is awesome. The color is gnarly. I love photography as much as jeeps. Ha
post #19650 of 28034 Old 09-11-2016, 10:29 AM
shaggyjim
NARF!
shaggyjim's Avatar
That's a drag. You weren't that far from me. I would have ran over to say hi if I had known you were on your way by. I have got the point were I don't get switches or sensors from autozone. I've still had good luck with Napa but other then that its getting to be OEM if I can.
Jim...
......YJOTM June 18......
shaggyjim is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Need a little tech help. tautog27 TJ Wrangler Technical Forum 10 02-24-2020 11:57 PM
This is not exactly tech gt4660 JK Wrangler Technical Forum 5 12-24-2007 05:56 AM
Water-proofing the Jeep...console, upholstery, etc. Let's chat. bman9089 TJ Wrangler Technical Forum 16 05-15-2007 06:38 AM
8.8 tech Greencar YJ Wrangler Technical Forum 4 09-20-2005 05:13 PM
