YJ AX15 Swap Problems - JeepForum.com
 4Likes
  • 2 Post By Tim742x
  • 1 Post By bruinjeeper
  • 1 Post By bpounds
post #1 of 10 Old 04-26-2020, 09:29 AM Thread Starter
Tim742x
Tim742x's Avatar
1987 YJ Wrangler
I bought a new Ax15 and NP231 to install in my 87 YJ. Everything went fine going in, new clutch and new external slave. All parts were sourced from Novak as a turn key transmission swap getting away from my BA10/5 that was locked up. Anyway my trouble is with the new transmission installed when I depress the clutch I was getting a horrible grinding noise. I removed and reinstalled the transmission 6 plus times trying various things, like replacing the new throw out bearing, realignment of the clutch, replaced the new pilot bushing. All to no avail. Finally, found that the noise is coming from the inspection plate rubbing on the flywheel when the clutch is depressed. Everything is bolted up (only 2 bolts at the top of the bellhousing and 2 bolts at the bottom on the inspection plate). But now Iíve noticed that the transmission is pushed back from the engine on the bottom half.
Iím thinking it it could be the following problems:
  • Engine / transmission alignment (I have to raise the transmission About 6Ē after mating to the engine)
  • Engine main shaft movement
  • Engine motor mounts ( causing the engine to tilt)
  • Replace the inspection cover (but it doesnít seem like itís a structural element)
Iím at a loss of what to try next. Obviously I need to drop the transmission back down to get the engine / transmission alignment back to neutral so I can mate them back together flush. I just donít understand if the transmission was designed for only the 2 top bolts what is causing them to separate on the bottom side.
Tim742x is offline
post #2 of 10 Old 05-01-2020, 12:00 PM
KARamsay
Did you use the right Pilot Bushing?
On the Early 258's it is a strange exchange.
It looks like your slave is loose in the photo.
Are you getting the trans seated/torqued properly?
Once that is on the engine they are pretty much one unit. Even with worn engine or mount bushings - you should not have a problem.
I have a few flywheels, and the cover that are getting ready to go to the scrap yard TOMORROW. You are welcome to them if you want. PM or call me.
BTW - I love the Orange / Tan.
KARamsay is offline
post #3 of 10 Old 05-01-2020, 12:20 PM
timatoe
timatoe's Avatar
Love the jeep!
I'd call Novak.
timatoe is offline
post #4 of 10 Old 05-01-2020, 12:34 PM
KARamsay
Originally Posted by timatoe View Post
Love the jeep!
I'd call Novak.
I assumed you had done that already... That would be my first step!
KARamsay is offline
post #5 of 10 Old 05-01-2020, 04:53 PM
bpounds
bpounds's Avatar
I'm not sure why the trans isn't going into place. Probably you had it before R&R 6 times, and now it just needs some finesse.
But the FW rubbing on the inspection cover, only when pressing on the clutch pedal, makes me think your crank thrust bearing is worn out. Crank slides forward and rubs.
I also know they sell a FW to crank flange spacer, but I've never been clear on what that is designed for. My 4.2 did not have it.
Bill
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 10 Old 05-08-2020, 07:05 AM Thread Starter
Tim742x
Tim742x's Avatar
1987 YJ Wrangler
Thanks, yes the slave was loose because I was working on it when I took the photos. I found my problem, basically Iím an idiot. I had left two side bolts out when I bolted up the transmission. One of those things where I convinced myself I had the basics correct and went chasing the obscure. It back on the road now.
bruinjeeper and bpounds like this.
Tim742x is offline
post #7 of 10 Old 05-08-2020, 09:27 AM
bruinjeeper
bruinjeeper's Avatar
Originally Posted by Tim742x View Post
I found my problem, basically Iím an idiot. ... It back on the road now.
if had a quarter for everytime . . .
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #8 of 10 Old 05-08-2020, 09:45 AM
LJameson
LJameson's Avatar
Glad you got it figured out, and don't beat your self up over it. I have lost count how many times I've been mentally exhausted trying to figure out something on a car, only to realize after a break and I have cleared my head that it was something simple.
1976 CJ7 Restoration:
LJameson is offline
post #9 of 10 Old 05-08-2020, 09:52 AM
bruinjeeper
p.s OP - you're a little low on post count for the May rendition, but if you put up 37 more technical forum posts (for a total of 50), you could be involved in June 2020 YJOTM.
it's a contest I host monthly with a line up of forum members' YJs voted on by forum members. Awesome prize.
details for this month is here:
https://www.jeepforum.com/forum/f12/...r-now-4395967/
bpounds likes this.
post #10 of 10 Old 05-08-2020, 09:55 AM
bpounds
bpounds's Avatar
I appreciate you coming back and letting us all know "the rest of the story". All too many of these things never get a final chapter.
Luuca likes this.
Bill
bpounds is offline
ax15 , transmission , YJ
