YJ is acting weird plus weird codes - JeepForum.com
post #1 of 9 Old 08-16-2015, 07:22 PM Thread Starter
DesertLight
Guys I really need your help. My YJ seems to be throwing me weird codes. I keep getting odd numbers or numbers that shouldn't exist. Like a 75 this time and last time a 76. Is my PCM toast? I got a youtube link to my video. I'm really at a loss here, I filmed it because I was frying in the sun inside the jeep. Please someone verify I'm not losing my d**n mind.
Some background, it doesnt have a/c and recently sat for a year until I fixed her up.
https://www.youtube.com/watch?v=MXQqiM5VJuc
DesertLight is offline
post #2 of 9 Old 08-17-2015, 06:58 AM
Que89YJ
Its and XJ controller. Those codes are normal for an XJ controller in a YJ. You need to be more descriptive in your post and try and provide info for the YJ.
Que89YJ is offline
post #3 of 9 Old 08-17-2015, 09:04 AM Thread Starter
DesertLight
It's in my jeep history. However these posts are rushed because I've been driving. All I'm looking for here is some help and/or explanation with wth is going on with my YJ. The battery and a/c circuit code, is fine. But idk about the 62 or even what I should do about that one. Then there are my mystery codes like a 75.. Also my cooling fan circuit (35).
post #4 of 9 Old 08-17-2015, 11:15 AM
Que89YJ
I didn't see a 62 in your video. I saw a 35 and 76.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 9 Old 08-17-2015, 11:18 AM
Que89YJ
Those are xj codes. What's wrong work the way it's driving ?
Fault codes:
No Start:
Que89YJ is offline
post #6 of 9 Old 08-17-2015, 11:28 AM Thread Starter
DesertLight
When driving it around, it feels funny. Like the engine is working entirely too hard when approaching 2k rpms. I would hesitate to take it beyond 2k, because it only seems to get worse, i.e. excessive jitter, shaking, and sound.
When I drive around in my XJ 2k rpms seems to just be dandy, not real loud and not a lot of jitters when accelerating. The YJ has new-ish engine mounts in it and are tight and steady. I'm trying to figure out why exactly it seems to be so loud and has a hard time at 2k rpms. Not to mention it sometimes shutters when slowing quickly.
Anyways this leads me to keeping it at or below 1800 rpms
(Both have I6s, XJ has an AW-4 and YJ has an AX-15)
post #7 of 9 Old 08-17-2015, 03:37 PM
Que89YJ
Check you air intake temp sensor.
Fault codes:
No Start:
Que89YJ is offline
post #8 of 9 Old 08-18-2015, 12:40 PM Thread Starter
DesertLight
Thanks Que, I will check it out and probably swap it next time I'm there with it.
post #9 of 9 Old 08-18-2015, 01:26 PM
Que89YJ
I would check it with a meter. I don't like throwing parts at problems.
Que89YJ is offline
code , codes , engine , pcm , wiring
