WJ Knuckle Swap - Page 10 - JeepForum.com
 7Likes
post #136 of 169 Old 02-05-2019, 09:59 PM Thread Starter
Awesome
Awesome's Avatar
I looked it up and the YJ and ZJ ball joints are the same - the WJ ball joint is indeed a different part.
Since the axle is the same, and therefore the axle C must be the same, the only variable is the knuckle. If the knuckle is indeed different, then you should use the correct part for the knuckle that you are swapping onto the axle.
scrogg likes this.
The 4th 5-seater YJ in the world.
Awesome is offline
post #137 of 169 Old 02-06-2019, 08:40 PM
V8orBUST
V8orBUST's Avatar
When I did my wj knuckle swap, either the upper or lower ball joint is different for sure. You need the 1/4" spacer ring to align the steering u joint, no other options. Depending on your setup, either use TJ hubs with wj rotors with 5x4.5 pattern drilled in, or do what I did and use a explorer sport track rotor with the YJ hub flange ground down a little bit and some shims to move the caliper out a hair.
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #138 of 169 Old 02-06-2019, 08:45 PM
V8orBUST
V8orBUST's Avatar
Spicer 707488X Suspension Ball Joint Kit
That was the ball joint kit I purchased.
It was a fun project and actually easy to do, worth it in my opinion and got high steer out of it too with a taper reamer. No regrets.
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #139 of 169 Old 02-06-2019, 08:49 PM
V8orBUST
V8orBUST's Avatar
A few pics to go with that
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #140 of 169 Old 02-06-2019, 09:26 PM
fishadventure
fishadventure's Avatar
You may not know - that’s fine. It’s not like you’d randomly measure this.
I have a pair of (not installed) wj knuckles. I went with tapered inserts for over-the-top steering instead. With my kitless ~1-1/2” lift (cut off factory perches and made very very short ones) this put me to exactly flat horizontal with the drag link. Slightly unexpected!
How much higher did your WJ tie rod mounting put you as compared to over-the-top? (If you know)
Thanks
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is online now
post #141 of 169 Old 07-21-2019, 08:01 PM
bruinjeeper
bruinjeeper's Avatar
curious question here - awesome right up, @Awesome
my steering is already set to cross over and am happy with it. How much better are your brakes with this swap? Is it that good that it is worth it for me to attempt? I have a line on a deal for the WJ knuckles (with spacers already welded on) and WJ calipers for $100... already have a dual diaphragm booster and MC upgrade sitting in storage.
Is the braking THAT much better to even do this in my situation? Or, is it more of a combination of the benefits (cross over steering + bigger brakes) which makes this such a valuable swap?
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #142 of 169 Old 07-21-2019, 09:29 PM
Steve707
Steve707's Avatar
I think I ran crown Vic rotors when I did mine.
Steve707 is offline
post #143 of 169 Old 07-21-2019, 09:41 PM Thread Starter
Awesome
Awesome's Avatar
Full disclosure: I did the 8.8 swap as soon as the knuckle swap was done. So I went from stock YJ to WJ brakes + rear disks at the same time.
The difference was huge. The only downside is the pedal becomes a little softer because there's so much more fluid in the pistons, but the Jeep stops real quick when I need it to.
I would recommend you buy pre-drilled WJ rotors. I know there's a couple of companies that offer them online. If it's cheaper for you up there in Canadia, you can buy the WJ rotors and have a machinist drill them for you. It cost me $45 to have a guy drill mine. He got the holes slightly off and I had to grind them out a bit.
I didn't have a drill press at the time, and it would cost me more than $45 in drill bits to drill all those holes.
I didn't do the swap for the brakes; I did it for the steering. The brakes were a happy bonus.
Crown Vic rotors are too small. I measured them in the junkyard.
EDIT: If I recall correctly, the Crown Vic rotors have too shallow a hat to fit properly. The hat might be too small in diameter as well.
The Sport Trac rotors are too small in diameter to use the whole brake pad. You'll have 1/8" or maybe a bit more of unused brake pad. They are probably the easiest option other than running pre-drilled WJ rotors.
Awesome is offline
post #144 of 169 Old 07-21-2019, 10:43 PM
Waternut
Waternut's Avatar
I have the 8.8, WJ booster/MC, and WJ brakes and knuckles. I did all of these one at a time so I can comment on this one. I'll order them from worst to best brake mods by performance.
1. The 8.8 disc brakes were trivial IMO. If I think about it, I can tell the brakes are better. However, with an older single diaphragm brake booster, the brakes still sucked.
2. WJ knuckles and dual piston calipers. Noticeable difference but I did already had the WJ booster at that time. The jeep dives under heavy braking because the fronts are so much better than the rear and it can be a bit alarming. I did it for the steering and SOA. I was ultimately happy with my brakes after the WJ booster.
3. WJ booster and MC. Huge difference in braking performance but as @Awesome said, the pedal feel is crazy soft and mine at least makes it feel like there is a ton of air in the lines.
Waternut is offline
post #145 of 169 Old 07-21-2019, 11:25 PM Thread Starter
Awesome
Awesome's Avatar
^ Yeah. I went from having a super stiff and responsive brake pedal (stock) to having one that feels like I'm going to mash it into the floor. The brakes themselves work amazingly, the pedal just feels soft. It's kind of hard to describe.
I guess it's like.... if you've driven a Ford, you know how crazy sensitive the gas pedal is, and then go drive a Chevy and notice how the pedal isn't nearly as responsive.
Awesome is offline
post #146 of 169 Old 07-22-2019, 05:41 AM
bruinjeeper
When I did the 8.8, I felt a very noticeable difference in braking.
I may be in the minority here. But i went from scary and hairy to really confident just adding the 8.8 in terms of braking. If I do this, I do not plan to do the dual diaphragm/MC upgrade at the same time. Saving that job for winter.
Still planning out. I dropped a ****load of cash in the past two weeks on the jeep (armor, new header). I mean, it's only $100 for the WJ knuckles and calipers.... but i wanted to confirm how significant simply the braking upgrade would be with the swap before I messed with my steering (,which I am happy with).
Thanks for the confirmation. Unsure if I'll go ahead with it.... may just pick up the parts for a down the line upgrade. Ideally I'd swap out the d30 for a waggy 44 if I were to be doin front end work. Have a line on one of those too, if the seller would only budge on not selling the 44 with a rear 9" as a set.
This information was useful as I've read multiple conflicting reports regarding how good an upgrade braking alone was with this WJ knuckle and caliper swap.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #147 of 169 Old 07-22-2019, 07:42 AM
Steve707
Steve707's Avatar
I dont know man, I've had them on for a while and can lock them up. They were 95ish crown vic I think. Theres no uneven wear on the rotors or pads. It does take a spacer between the bracket and caliper though, 1/8" I think.
Steve707 is offline
post #148 of 169 Old 07-23-2019, 12:05 PM
Stitch586
Stitch586's Avatar
If you go through with it, I would recommend to try using off the shelf parts. If you would like, I can go through my notes and give you my part numbers when I did my WJ swap. I cant remember exactly which rotor and wheel bearing I went with, but I ended up making a "spacer" the went between the wheel bearing and back face of the rotor.
I though I would never change my brakes the rest of my Jeeps life until my passenger caliper locked up on me trashing my pads and rotor. It was nice to just go to the store and not having to order a special rotor or drill out a bolt pattern.
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
Kilo-Echo-8 * * *
Stitch586 is offline
post #149 of 169 Old 07-23-2019, 12:08 PM
bruinjeeper
I'm sure anyone who reads this in the future would be appreciative.
That'd be a big help. Thanks
Siva283 likes this.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #150 of 169 Old 07-23-2019, 01:36 PM
Waternut
Waternut's Avatar
I would appreciate it as well even though I already did it. There are so many threads about the WJ brake swap and so many are "I think these rotors will work" followed by someone saying they didn't look the same at the junkyard and another guy claiming he'll buy the parts and report back...but no one ever reports back. I drilled out the WJ rotors bc that was the only proven thing at the time but I don't want to drill rotors ever again.
Sent from my Pixel 2 using Tapatalk
Waternut is offline
