At wits end with Weber - JeepForum.com
post #1 of 80 Old 03-03-2010, 01:43 PM Thread Starter
CTJeepin
1987 YJ Wrangler
Guys, like it says, I'm at my absolute wits end with this Weber 34. It's got about 100 miles on it and I'm ready to toss it in the garbage. I'm also willing to accept that there may be some user-error involved as well.
It's always run rich since the first day I put it on and tuned it. I brought it to a mechanic friend last week to see if he could do something that I wasn't able to. He made some minor adjustments but couldn't come up with anything that made any improvement. He told me that Webers tend to run rich because of the stock jets that they use. Mine was shipped with a .150 primary run jet and a .147 secondary. My idle jets were 65 primary and 47.5 secondary. He recommended that I go with a 145/147 run jet combination and a 35/35 idle jet combo. I ordered everything from Weber and installed the jets today. The horribly gassy exhaust fumes are gone but now I can't get the thing to idle under 2000 rpm's no matter what I do. The choke isn't sticking either. I don't have a clue what to do with this thing. Does anyone have any advice? Thanks.
CTJeepin is offline
post #2 of 80 Old 03-03-2010, 02:47 PM
PrinothPro
do you have fuel pressure regulator hooked up? Webers tend to run rich without FPR, I know i did with my 32/36.
You should chat with mcmud. He is genius with Weber and help me tons.
PrinothPro is offline
post #3 of 80 Old 03-03-2010, 02:48 PM
vector6
did you try this.. ?
Weber Carb Tunibg
vector6 is offline
post #4 of 80 Old 03-03-2010, 05:43 PM Thread Starter
CTJeepin
1987 YJ Wrangler
Weber Carb Tunibg
Yes, that's exactly the article that I followed. Also, I have a Holley FPR set at 3psi. I wonder if re-jetting did more harm than good. Should I go back to stock and live with it?
CTJeepin is offline
post #5 of 80 Old 03-03-2010, 07:49 PM
RedneckJacob
1987 YJ Wrangler
you could send that weber 34 my way CTJeepin.....
RedneckJacob is offline
post #6 of 80 Old 03-03-2010, 08:32 PM
PrinothPro
I know it is quite a distance for you but can't hurt to check the Hobbs Carburetor shop. I recently took my weber there in NH and they completely cleaned up my weber up, did whole 9 yards with it and cost me less than 100 bucks. Bolt on and go, they are amazing so you could check it out. You can try google to see if there is any place nearby. Good luck with your weber.
post #7 of 80 Old 03-03-2010, 08:38 PM
windsoreight
windsoreight's Avatar
I feel for you, I went through the same with my 34. I ended it replacing it with a Holley 350. The difference is amazing. I would suggest take your loss and pick up a motorcraft. I was able to sell my weber to pay for my holley.
1999 XJ 2 door, 4.0 HO, Auto trans, Rough Country 4.5" lift, Ion wheels, 33/12.50/15 BFGtires, Getting it ready for paint.
1987 Wrangler, 4.2L, Holley 350cfm carb, TF999 Auto trans, NP207 transfer case, Rough Country 4" lift, Mickey Thompson limited edition wheels, BFG 33/12.50/15 tires.
windsoreight is offline
post #8 of 80 Old 03-03-2010, 08:40 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I am sure it just needs adjusting, if it helps at all I have two 145 jets. Don't know about the air jets but I could check what I have if removing them will not mess my carb up. I have a 32/36 though
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #9 of 80 Old 03-03-2010, 09:09 PM
rexryman
1987 YJ Wrangler
get the holly fuel pressure regulater.
i have the webber 34 and i had trouble for a while until i got the fpr.
and now it works great
the holly fuel pressure regulater costed about 30 dollars and then it cost about 10 dollars of fittings to put it in
now i idle at about 975-1000 and it dosent shake either it runns pretty smooth
rexryman is offline
post #10 of 80 Old 03-03-2010, 09:11 PM Thread Starter
CTJeepin
1987 YJ Wrangler
I have that installed already and set at 3psi. I don't know what the problem is...
CTJeepin is offline
post #11 of 80 Old 03-03-2010, 09:16 PM
windsoreight
There is a difference between the Weber 32/36 and the 34. THe 34 is not a true Weber. It is an Empi sold under the weber name. I found this out when I talked the weber. The 34 in my opinion is over complicated junk. My jeep ran ok, it never ran rich or lean but had no power. I get better mileage and power from the holley. I spent enough time with mine to realize you were only able to get so much out of it. It is an ok carb but don't expect too much.
post #12 of 80 Old 03-03-2010, 09:18 PM
rexryman
1987 YJ Wrangler
did you do the jerry rig throttle return!!!!
i will take a pic of mine in like two mins
rexryman is offline
post #13 of 80 Old 03-03-2010, 09:20 PM
PrinothPro
Oh I forgot to mention, I researched on weber so much I found that sometime weber does better with pinched fuel return line or smaller line. Something like that. I can try find the info for you?
post #14 of 80 Old 03-03-2010, 09:20 PM Thread Starter
CTJeepin
1987 YJ Wrangler
Ya, I had to because the stock return spring wasn't strong enough to pull it back. I fab'd up a bracket and connected a heavier spring to it.
CTJeepin is offline
post #15 of 80 Old 03-03-2010, 09:26 PM
rexryman
1987 YJ Wrangler
does it pull the throttle all the way back it took me two trys to make the bracket pull the throttle all the way back, and it made me idle at about 1700rpm
rexryman is offline
4.0 Idles great, but if you press the gas it wants to stall- @wits end here proeliumfessus YJ Wrangler Technical Forum 41 01-04-2010 03:17 PM
I'm at wits end over my axle - need opinions! fyrdriver YJ Wrangler Technical Forum 10 03-05-2009 09:15 AM
at my wits end KenJ95 YJ Wrangler Technical Forum 7 11-28-2008 10:39 AM
At wits end! mgaspard TJ Wrangler Technical Forum 14 11-09-2006 12:16 PM
'95 Wrangler accel Breakup -- any ideas? at wits end harley1200 YJ Wrangler Technical Forum 2 07-24-2006 12:05 PM
