Wiper Motor to linkage - JeepForum.com
post #1 of 12 Old 10-23-2010, 08:11 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Anyone here have any pics of how the wiper motor is attached to the linkage for the wipers. I need to to know how the actual motor is attached to the small linkage part (around 6 inches) thanks....
nedmoore is offline
post #2 of 12 Old 10-23-2010, 08:13 PM
gunshw301
gunshw301's Avatar
Do not remove the nut holding the metal arm to the motor. I will find my manual and take a pic, its simple once you see it in writing.
gunshw301 is offline
post #3 of 12 Old 10-23-2010, 08:23 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Too late Gunshw301! I did a YJ tub swap on my cj, used the YJ windshield frame that had no motor. Bought a used motor on ebay. I have the metal arm that attaches to motor though...
Damn! That was a fast reply! Thanks.
nedmoore is offline
post #4 of 12 Old 10-23-2010, 08:24 PM
gunshw301
gunshw301's Avatar
Sorry, I am in the process of moving my wifes stuff into the house, so I have no idea where that book is right now. If i remember right there are ball and plastic cups that hold the assembly together. You have to pry on them some how to get them to pop off. I did this years ago so its a little fuzzy now, but it was really simple when I figured it out. Just dont remove that nut, its impossible to put back on right, then it will just come loose again. I had to weld mine back together because the splines stripped when the nut backed off....basically its a pain.
post #5 of 12 Old 10-23-2010, 08:29 PM
gunshw301
gunshw301's Avatar
Grab one of the haynes manuals if you can. I know some guys say they are junk compared to a shop manual, but I have had most of my problems solved by either it or the forums. The write up in the manual was good enough for me to get things back together. Unfortunately I bought it after I had things torn apart, the very first thing in bold is dont remove that nut.....I had already figured out why.
post #6 of 12 Old 10-23-2010, 08:41 PM
gunshw301
gunshw301's Avatar
ha, found it, give me a sec and i will post some pics
Hope thats what you were looking for, good luck with your project.
post #7 of 12 Old 10-23-2010, 09:11 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Thanks so much, I'll keep you posted.
nedmoore is offline
post #8 of 12 Old 11-04-2010, 05:38 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
Any ideas on what to do if the nut was removed? I bought the wiper motor on ebay....
nedmoore is offline
post #9 of 12 Old 11-04-2010, 05:50 PM
gunshw301
gunshw301's Avatar
Do you have the metal plate? If so, look up a picture of the motor for sale on line. Line up the plate as best you can from the picture and place the plate on. Then tighten the crap out of it the best you can. Now one of two things will happen. 1. It will stay there and work. 2. It will work for a short period of time and then slowly stop working. If number two happens, then the splines have worn away because the plate became loose. If this happens, line the plate back up on the shaft and place a couple good tack welds to the shaft.
Thats what I had to do and its been working great for years now. Just try to line it up the best you can. If its off a little it will be okay, mine is a tad off and the wipers dont cover the original area, but its livable.
post #10 of 12 Old 11-04-2010, 06:17 PM
gunshw301
gunshw301's Avatar
I should clarify. Weld the plate to the splined shaft and not use the nut.
post #11 of 12 Old 11-04-2010, 06:53 PM Thread Starter
nedmoore
nedmoore's Avatar
1982 CJ7
I have to check if I have the plate, this has been a tub swap and everything else that comes with it! What if I do not have the plate? Fab one?
nedmoore is offline
post #12 of 12 Old 11-04-2010, 07:18 PM
gunshw301
gunshw301's Avatar
It should be easy enough to make. It wouldnt have the splines unless you have a way to do that, but the weld route would work just fine.
wiper linkage help skidawgz YJ Wrangler Technical Forum 5 02-13-2010 08:34 AM
How do I remove the windshield wiper motor and linkage? Goobersbro YJ Wrangler Technical Forum 6 01-03-2010 11:43 PM
Wiper linkage Ptr YJ Wrangler Technical Forum 3 06-28-2009 06:49 AM
wiper linkage roadyrob YJ Wrangler Technical Forum 3 11-22-2007 08:02 PM
wiper linkage f1ipst3r YJ Wrangler Technical Forum 6 02-14-2007 08:38 PM
